AC not very cold?
1--73---80
2--69---73
3--75---76
4--75---71
5--75---75
6--71---118
7--05---11
8--69---111
9--27---27
10--6.0---6.0
11--3.1---2.6
12--4.3---4.2
20--3.2---3.2
21--32---32
22--00---00
23--32---32
24--11.4---11.4
40--164---164
41--85---85
42--08---08
43--136---136
Thank You again.
Contrary to some belief, models of that era (W202s, W210s) don't have a widespread history of evaporator leaks, unlike the previous models (W124, W140, etc.). So jumping to that conclusion isn't warranted.
1--80
2--82
3--5
4--44
5--55
6--193
7--driving around about 25 mph up to 60 mph it stayed about 07, when stopped and still idling it went up to 20 and then 11, then back to 07-08 when driving.
8--148
As a guess I am going to assume that reading is a typo. I am also suspicious of the #7 reading rising to 20 -which is OK, but the falling off to 11 (at idle. anyway), With my assumption in mind I am suggesting you get some gauges on it so you can observe both the high side pressure, which is #7 (in bar) and the low side - which is not available from the pushbutton module. It could be a low charge - certainly plausible after 22 years. At idle on a warm day - 80 degF - you should see approx. 35 psi (2.4 bar) on the low side and approx. 250 psi (17 bar) on the high side. If the system seems in good order except for a low charge I would have the system evacuated and make sure it can hold a vacuum for at least several hours which will confirm that there is no serious leak. Then recharge with 35 oz. of R134a and see how long that holds. If you don't have the tools and skill to do this find a reputable shop.
You obviously have deep & extensive knowledge on MB Air Conditioners. Thanks for enlightening me.
2--84
3--62
4--55
5--73
6--193
7--23, with fluctuations between 7 to 19.
8--161
This is my wife's car so I do not drive it to often. The air is cold but she tells it should be colder. Maybe I am looking for a problem where there is none??? Thank You to all for your input.
I assume it's part age (mine's 23 yo) and part better technology in newer units.
My last evacuate, vacuum, oil & recharge was like $250 - not that different than your quote.
R134a branded as SuperTech is virgin, US made refrigerant without oil, dye or sealant It is available on Amazon and at Wall-Mart. I have used the self sealing cans and they seem to hold quite a long time.
In over 30 years I have never had a problem with the high side port.
By 2030 gas vehicles banned etc in WA anyway and I'll be rocking it and showing off in my new Flintstones car.
