w210 e320 1999 wagon EGR valve quick help?? pls thx
so this will requires someone that is very familiar with egr stuff....and i get that i may not get answer in time before tomorrow for when i can call him....but i give it a shot
its kinda warm out still and want to try now this evening
so my MB guy from mass who is really very savvy... he was telling me about a diagnosis procedure to perform to maybe ascertain if it is the egr valve or vacuum line
and we had bad signal at the time and i thought i understood him clearly enough to understand ....but tbh now im not so sure
and it is 8pm here and hes not open now
so he said for me to find the egr valve, and the vacuum elbow the line to valve. and remove it and plug it....
should get check engine but it should also allow for it to run smoothly and would determine if it is clogged egr line or vale mishap
so the only line i see, or have easy access to on the egr valve is the aluminum one on top that has two nuts on it.
was that the one he was referring to? i don't recall hearing him say to back nuts off...so maybe he was referring to the hose off/from the valve covers? or the vacuum producing line? but that is like way under the valve i think or believe. idk after typing all this out i almost feel i might as well just call him back tomorrow
idk maybe one you guys have done or tried this before and can advise??
but if i wanted to try this procedure he described to me, so i could get to work and eat and stuff, then i could have a go at looking at the line egr valve. otherwise he couldn't take it on till after thxgiving bc he has 3 convertibles he needs to get thru first. so i figured i would come and ask the forums maybe someone else has done this procedure and knows intimately what he might be referring to so i can get to work and stuff
