Front crankshaft seal installation questions.
Old Dec 8, 2022 | 06:57 PM
e320revival's Avatar
2001 e320
Hi. I have a e430, and I replaced the front crankshaft seal. It is now leaking. I tapped it in instead of using the special tool, and I used an aftermarket seal, a brand called corteco. My main question is, is the corteco brand seal any good? And also I didn't turn the crankshaft pulley bolt the additional 90 degrees after installing the bolt. Does the crankshaft pulley press against the seal and help stop oil from leaking? If you don't get the 90 degrees turn after you torque the crankshaft bolt to 200 nm, would that cause an oil leak between the pulley and the crankshaft? Thnx in advance.
Old Dec 9, 2022 | 01:27 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
I cannot speak to the front oil seal but I can tell you that since you failed to torque that bolt the additional 90° as required you're asking for the harmonic balancer to fall off the front of the engine. You won't be the first.
