Alarming Question?
Old Oct 22, 2004 | 05:15 AM
E320Star's Avatar
2000 E320 Sedan
Lightbulb Alarming Question?
I have the security alarm red light mounted in middle of the dash board,and it never blinks when the car is locked! Does that mean I do not have a security alarm in the car!! What is the deal. Thank you
Old Oct 22, 2004 | 01:00 PM
EddieGTP's Avatar
Not a Benzer anymore
The Tow Away Alarm
According to the Manual:
The switch is located in the center console.
1 Press to switch off
2 Indicator lamp
Once the alarm system has been armed, the exterior
vehicle lamps will flash and an alarm will sound when
someone attempts to raise the vehicle.
The alarm will last approximately 3 minutes in form of
flashing exterior lamps. At the same time an alarm will
sound for 30 seconds. The alarm will stay on even if the
vehicle is immediately lowered. To cancel the alarm,
insert the electronic key in the steering lock or press
buttonOE or‹ on the electronic key
If the alarm stays on for more than 20 seconds, an
emergency call is initiated automatically. See Tele Aid
on page 178.
To prevent triggering the tow-away alarm feature,
switch off the tow-away alarm before towing the vehicle,
or when parking on a surface subject to movement,
such as a ferry or auto train.
To do so, turn electronic key in steering lock to
position 0 or 1, or remove electronic key from steering
lock. Press tow-away alarm switch (1). The indicator
lamp (2) illuminates briefly.
Exit vehicle, and lock vehicle with the remote control.
The tow-away alarm remains switched off until the
vehicle is locked again with the electronic key, at which
time it is automatically reactivated.
It could be a fuse?
Old Oct 28, 2004 | 02:54 PM
E320Star's Avatar
2000 E320 Sedan
Exclamation
Does E320 2000 MB come with a security alarm with standard equipment? The red light in the middle of the dashboard right under the windsheild in the middle is not blinking red when the car is locked? Does it mean i do not have an alram in the car? Thanks
Old Oct 28, 2004 | 03:49 PM
The Godfather's Avatar
4 wheeled car.
It's not a light like on the BMW, it's a light sensor or something like that.
Old Oct 28, 2004 | 04:25 PM
E320Star's Avatar
2000 E320 Sedan
Exclamation light sensor
What is th elight sensor for?
Old Oct 28, 2004 | 04:55 PM
deuce zer0's Avatar
E63
i would bet anything that ur car came standard with a security system. i was under the understanding that the ignition was tied into the security system. if the security system didnt work, could u use the car?
i would think that just because you dont notice its working doesnt mean its not. there are ways to set it off urself to actually see if its working. lock the car with ur key and then open it car from the inside. it should go off then.
if not then....it obviously doesnt work.
Old Oct 29, 2004 | 04:57 PM
EddieGTP's Avatar
The Center Light Sensor (Pyramid like Shape)
Interacts somewhat with climate control system.
