Youcanic Code Reader and 38 Pin Arriving Today...
Old Jun 9, 2023 | 09:04 AM
Teutonic_Driver's Avatar
E320 4matic
SRS light is back on after I seemingly fixed it by taking apart the front passenger seat and cleaning/reconnecting everything. I decided to splurge and buy the Youcanic reader to reset the light and diagnose the issue. Looking forward to having this tool for my other rides, too.
Old Jun 10, 2023 | 01:27 AM
davmil2002's Avatar
320e
Please post how it works on your MB. Thanks
Old Jun 12, 2023 | 08:25 AM
E320 4matic
Got the scanner this weekend. In a word: impressive. Impressive build quality. Impressive screen size and resolution. Impressive comprehensive support for vehicles. Impressive functional options. Wow. Best money I've ever spent on a repair tool.
Worked like a dream on my W210. I reset my SRS light and then ran -- and emailed the report -- to my email box. Turns out there are a heck of a lot of errors in my ECU. I'm not sure I understand all of them or how to fix them. Seriously. I'm not qualified to interpret these codes (I'd appreciate any insights this community may have):
ETC-Electronic transmission control
ID Status Description
116 Stored Component Y3/6s1 (Starter lockout contact) or the lead occasionally has a short circuit.
135 Stored CAN communication with the engine system is sporadically disturbed.
ESP-Electronic stability program
C1120 Stored N64 (ESP yaw rate sensor)
C1140 Stored N49 (Steering angle sensor) Signal cable has Open circuit or Short circuit.
C1504-009 Stored The system is switched off.Steering angle sensor is not initialized.
AB-Airbag
B1871-004 Stored The resistance value in the ignition circuit containing component R12/21 (Right front side airbag ignition squib) is too high.
ICM-Instrument cluster with maintenance interval display
B1108 Stored Fault in CAN communication with control unit N73 (EIS [EZS] control unit).
Vehicle Diagnostic Report
B1110 Stored Communication through the interior CAN bus is faulty.
B1125 Stored Fuel level sensor: open circuit in signal wire
B1129 Stored The ambient temperature sensor has Open circuit.
EZS-Electronic ignition switch
B1010 Stored The supply voltage of the control unit is too low (undervoltage).
B1011 Stored The supply voltage of the control unit is too high (overvoltage).
B1053 Stored Fault in CAN communication with control unit DCM-RR.
B1023 Stored Fault in CAN communication with control unit N32/2 (Right front seat adjustment control module with memory).
OCP-Overhead control panel
LCP-Lower control panel
B1119 Stored Test switch N72s6 (Exterior mirror up/down switch) for , and replace if necessary.Short circuit to ground Test switch N72s7 (Exterior mirror left/right switch) for , and replace if necessary.Short circuit to ground
PSE-Pneumatic system equipment
B1436-014 Stored The safety time of the central locking has been exceeded for the following pneumatic branch:Front passenger door or rear doors
B1436-013 Stored The safety time of the central locking has been exceeded for the following pneumatic branch:Fuel tank cap
B1440 Stored The safety time has been exceeded for the following pneumatic branch: Trunk lid remote release
B1439 Stored The safety time has been exceeded for the following pneumatic branch: Manifold vacuum assist
B1436-012 Stored The safety time of the central locking has been exceeded for the following pneumatic branchriver's door
B1712 Stored The alarm has been activated through component S17/3 (Left front door contact switch).
B1709 Stored Component H3/1 (Alarm signal siren with additional battery) is Not coded or FAULTY.
B1713 Stored The alarm has been activated through component S17/4 (Right front door contact switch).
B1715 Stored The alarm has been activated through component S17/6 (Right rear door contact switch).
B1710 Stored The alarm has been activated through component S17/8.
SAM-Signal acquisition and actuation module
B1217-002 Stored Component B38 (Rain sensor) is faulty. No windshield adaptation is possible.
B1217-003 Stored Component B38 (Rain sensor) has excess temperature.
DCM1-Door control module front driver side
B1407-001 Stored Component E17/9 (Driver entry/exit lamp) has .Short circuit to ground
DCM2-Door control module front passenger side
AUDIO
N1141 Stored&Current Set-actual configuration of D2B ring differs
U1100 Stored Please refer to vehicle service manual!
E-call [USA]-Emergency call system
N1261 Stored The life signal of the airbag control unit cannot be received.
Old Jun 15, 2023 | 08:19 AM
E320 4matic
Hey Plutoe, googled "stored faults." Not sure what I'm supposed to find, there's a crapload of related information that comes up. I'm going to infer from your post that my list of error codes are historical and a non-issue. That'd be great if true. Cheers.
Old Jun 19, 2023 | 08:47 AM
E320 4matic
Does it matter that this doc appears to be for the W203?
Old Jun 19, 2023 | 08:05 PM
E320 4matic
After I cleared the codes, the SRS light returned immediately upon start up. I'm going to pull the door trim and look at the wiring to the side airbag. Maybe unplug and clean the terminals with contact cleaner and then snap back together. Hopefully I won't set off the bag's detonator. : (
Old Aug 7, 2023 | 09:01 AM
E320 4matic
After much research, I decided NOT to try and clean the side airbag contacts. Instead I found a post that said the under-seat connectors should be cleaned with contact spray. So I did that. Reset the SRS lamp with my Youcanic tool and then disconnected the battery for a few hours.
When I fired her up, the SRS light was gone. : ). But the ASR and ABS warning messages appeared. Youcanic said the error code was because the steering angle sensor was uninitiated or something. I recalled that if I turned the wheel all the way left and then right it would reset the component. It did.
All dashboard lights are off now. Fingers crossed. Hoping this helps somebody in the future with the same issues. (FWIW, my 2000 E320 4matic has only 78k miles).
Old Aug 8, 2023 | 03:57 PM
E320 4matic
Dagnammit. The SRS light is back on. : (
Looks like cleaning the side airbag electrical contact is next. If that doesn't work I'm afraid it's the dealership next... $$$$$. : (
