2001 E320 7.22 OEM transmission oil color
I’m going to order the necessary transmission oil dipstick kit with the locking pins and o-rings for my 2001 E320 with the 7.22 transmission. What is the color of the OEM fluid from 2001? I see various transmission fluids available but they seem to be red in color. I thought my transmission fluid was more of a slightly yellow / clear color.
Thank you
Richard
Thank-you!
Some years back I had developed a minor drip-type leak and the repair facility replaced some-sort of sensor on the transmission oil pan. Hence, when I saw the ‘fairly clear’ fluid, I just assumed it was the same issue. I didn’t know the transmission fluid was actually red.
So, ten years ago I purchased a transmission fluid dipstick for my W210 but never used it. Today I tried it, hoping to determine the transmission fluid color for myself. The dipstick would only drop down about 7.75”. No matter how I rotated it, it didn’t want to go any further, though I did try three or four times. Since it’s a plastic piece on the end, I wasn’t interested in pushing my luck and breaking it off into the transmission pan.
Anyone have a recommendation for the dipstick that has a narrower connector that actually fits into the dipstick tube?
Thank-you
Richard
