AC system gremlins, won’t blow out of correct vent, sometimes AC is heated
I have a Mercedes Benz E320 wagon that has an AC issue going back a few years. At first it would take 15 to 20 minutes for cool air to start coming out of the center vents. Every time I restarted the car it went through this process. At some point, it quit blowing out of the center vents entirely, and there was no more AC.
About a year ago I replaced my battery. Upon doing this the AC worked great again. The AC worked fine for a couple months and then quit blowing out of the center vents again.
If I leave climate control set to blow out the center vents it will blow when I first start the car, as soon as the car starts driving the air switches to blowing out of the defrost vent. I have noticed recently that I can get full on heat from vent while set to low temp. The problem appears to be getting worse.
I have had a couple mechanics take a look at it. One replaced the expansion valve and recharged compressor which didn’t fix anything. I have a feeling it is a simple fix that very good Mercedes mechanics know about, but I have been unable to get this addressed.
I appreciate any knowledge or suggestions that any of you have 🙏
![](https://cimg9.ibsrv.net/gimg/www.mbworld.org-vbulletin/640x480/images_jpeg_15_2dcfedea3542e256ed5158e63a19fcc4e8313e78.jpg)
![](https://cimg8.ibsrv.net/gimg/www.mbworld.org-vbulletin/541x567/images_jpeg_10_741ac0023886f6b9b0f25444b8d51264f1d00886.jpg)
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Nope not that hose as all flaps are under dash----go to the stickie and look for the W210 flap test do the test and you will then know what flap or flaps are the problem
And changing the faulty actuators is a big deal with dash removal
