Substitute Radio for '97 E-420?
1 Post
Late Built 2005 W-211 E-320 CDI
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Asking for my daughter and son-in-law . .
Their original factory radio has given up, and I was wondering if anyone knew what was a
good unit to install instead of the terrible original factory one?
He is mainly interested in good AM reception which the original radio never did at all well.
Not really concerned about hi-fi or music, but a unit that will do what the factory radio never did well.
A good installer in the South Bay area (Torrance, Redondo Beach) would help also.
Any suggestions? Please help, as I haven't a clue!
I'd give him the one from my '99 but mine has fibre optics, and his does not, I think?
Thanks in advance.
E430
If he doesn't care too much CD and only needs AM and he's got a pre-fiber car, he should be able to go any stereo shop and buy a simple radio and harness for cheap. Probably, not much more than 200 bucks should be all, if that.
Of course, there's always ebay. Tons of used radios there. Lots of factory radios too.
good luck,
-travis
good luck,
-travis
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Thanks in advance.
Your 1999 radio should work in his car, but will not operate the CD changer (if one is installed)... so you should not plug in the C connector.
Also, Steve has an Audio 10CD which would work well also.
Note that the poor AM reception may have something to do with the antenna amplifier.
-s-
MY2004 E320
Non Fiber single Cd????
Never heard of this one, can you post a bigger pic? maybe I can look it up on the web. I have been looking for a while for a single cd that can operate my OEM changer
1 Post
Originally Posted by scorchie
Note that the poor AM reception may have something to do with the antenna amplifier.-s-
Scorchie . .
Is it difficult to replace that amplifier, and where is it located?
Also, where is the best place to buy a new antenna amp., and how much are they?
I'll try that first and go from there.
Anyone ever deal with Crutchfield?
I'm thinking about buying a replacement radio from them if it comes to that which I'm sure it probably will!
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
Thanks in advance.
1 Post
![Wink](https://mbworld.org/forums/images/icons/icon12.gif)
Dean B,
Car is fixed now.
Took a local radio shop fellow less than five minutes to repair.
This shop was recommended by a good independent MBZ shop in the South Bay area. Turned out to be a loose connection I think.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Kevin said it was behind the left rear grip handle, sort of behind the headliner (?)
Before going to the independent MBZ shop and then on to the radio shop, K.
called the local Torrance banditos and was quoted over $600 for the antenna
amplifier plus more than $2000 for a new factory radio! Can you believe?
It's no wonder MBZ is loosing customers. They cannot make profits selling cars, but sure do selling parts.
Thanks again, and I'll be watching for a Pacer for you. I read the L A Times'
classifieds every weekend, so if there is no advertised, I'll let you know.
Derrel
97 E320, 98 S70, 02 HD VROD
Originally Posted by E55 KEV
I sent out a couple emails trying to get a part number:
![](https://mbworld.org/forums/images/ranks/veteran_air_force.png)
After it was detemined that the problem was not in the radio itself, but in the antenna
connection which was simply loose, there was no need to replace the radio.
K. says everything is working properly now, the same as it
did when the car was new some eight years ago.
