driver's side mirror
Old Nov 8, 2004 | 02:54 PM
galleryvw's Avatar
1997 E420, 1983 300D
the other day i noticed my mirror vibrating at highway speed - i looked at it in the driveway and noticed it was completely loose! Just about hanging on by the wires. i popped off the cover, and found one of the hooks that holds the spring had broken. i used some wire to hold it together temporarily, but since i'm going to have to replace it anyways, how hard is it to come across the folding mirrors? i haven't seen them for sale on the web. if i go with OEM replacement, is the mirror all one part, or can i buy just the metal piece that holds the spring?
thanks,
-v
Old Nov 8, 2004 | 03:07 PM
galleryvw's Avatar
i'm seeing the OEM mirror for $310? that's a lot more than i was expecting
Old Nov 8, 2004 | 03:37 PM
SmokeSilver's Avatar
1997 E420
Same thing happened to me...
Mine broke off in a car wash. I was able to stretch the spring and attached it to another piece of metal inside the unit. I will have to break down and pay the $300 eventually...
Very poor design...
Old Nov 8, 2004 | 03:57 PM
galleryvw's Avatar
attached to another spot? i'll have to take another look in there. i couldn't really find a spot close enough - that spring is tight! did you drill a hole? i was considering that, but it was getting late.
v
Old Nov 8, 2004 | 04:31 PM
mbmiller's Avatar
E320
One end of mine broke off while I was installing my signal blinkers, I used about 10 rubber bands connecting to the spring, and wrapping around the entire end portion to loop back to the spring. Not as tight as the OEM unit, but good enough for it not to move at all while driving. I should replace it though, mine is a 97 mirror (not foldable), I've seen then pretty cheap on ebay.
MbMiller
97 E320 83K
Old Nov 8, 2004 | 04:39 PM
galleryvw's Avatar
if i'm not mistaken, it's just the covers on ebay that are pretty cheap, i'll look again though. right now, mine is pretty tight, but the cover is not slipping all the way on, i'm thinking it is hung up on my little wire tie quick fix
Old Nov 8, 2004 | 06:02 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
quite a lot of forum members here swapped their mirrors out for blinking mirrors...there should be an abundance of regular non blinking 210 mirrors available here...make sure you buy a mirror that has the memory motor instead of a standard non memory motor when you find a used one...
greetingz,
Old Nov 9, 2004 | 03:16 PM
my E430 rocket's Avatar
BMW X3. R33 skyline
yup my passenger side has no spring attachment as we speak. i was quoted $500 to replace
Old Dec 25, 2004 | 02:06 PM
jemmy's Avatar
99' E320
i'm wondering why i just can't fold my both side mirrors even by hand? it is a classic and is somebody outhere can give me some advice about upgrading the mirror with the one that avantgard is equipped with? and where would the button be installed on my dash?
Old Dec 25, 2004 | 04:08 PM
Whitey's Avatar
98 W210 Advantgarde
Steve MBenzNL will be able to help with getting you the Advantgarde powered folding/memory mirrors.
I'm really surprized the regular ones can't be folded....I thought that would be a standard damage preventive design - all other cars have them...weird.
Mine is an Advantgarde and the switch is located on the driver's side between the mirror toggle and button for the power rear shade...of course, it should be on the other side for the US.....
Old Dec 25, 2004 | 04:28 PM
paomien's Avatar
From: Long Island, NY / Mississauga, Ontario / Changhua, Taiwan
11 S550V4
I agree with whitey ....
The switch is actually in the same place as european / asian market cars, next to the rear sunshade button, on the right side of the car.
Damn whitey I want that Parktronic button, then I'd really have a dashboard with every single available switch :p
Old Dec 25, 2004 | 10:39 PM
BMW X3. R33 skyline
i like my parktronic but i don't like how it comes on every time i start the car
Old Dec 25, 2004 | 11:52 PM
Whitey's Avatar
98 W210 Advantgarde
I'm sure a certain Dutch fella will be able to help with that:p.......
