Problem Startin My Car
- the engine will turn over but not start (fueling issue either mechanical or electrical)
or
- the engine will not turn over (starter issue)
Hell, it's a diesel and those things are hard to kill. Fuel pump fails to operate would be heat-related issue in the SAM or pump itself. Relay flips on, power to fuel pump, pressure to fuel rail. Is there a shut-off mechanism (flapper that closes off the throttle body) that has a solenoid that could heat-soak? I'm reaching here as I don't own a diesel version.
And take Raymond_g- advice. Pull codes and let us know.
