AMG muffler on e320
Old Nov 18, 2004 | 05:25 PM
Shane C's Avatar
E320
AMG muffler on e320
just picked up a e55 amg muffler how hard is it to install on my e320 are they same dual /single inlet and size or will i have to do some more modification. would also like to remove mid muffler!
will use in conjunction with florinser rear bumper hehe
Old Nov 19, 2004 | 02:13 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
what year is your E320? All US E55 AMG mufflers have dual inlets, but there is an W210 AMG muffler with one inlet. All W210's from 1996 to 1997 have single inlets. The stock muffler and mid-muffler is one piece unit and has to the cut to install the AMG unit.
Old Nov 19, 2004 | 02:54 PM
Shane C's Avatar
E320
Mine is 96 e320
after climbing under the car i see that my stock muffler has single inlet, mid muffler has 2 inlet single outlet. If i remove the mid muffler i should be ok right?
does anybody else have this set up?
Old Nov 21, 2004 | 08:39 AM
E-Klasse's Avatar
W205 C300
Here is my aftermarket exhaust setup.
Mine came with a mid-muffler with dual output.
Old Nov 21, 2004 | 09:58 AM
Whitey's Avatar
98 W210 Advantgarde
Yep, if you removed the resonator/mid-muffler, you'll have two straight pipes to go into your new E55 exhaust. I had to make a "Y-joint" to fit my straight pipe to the single inlet of my Sebring muffler:
Old Nov 21, 2004 | 09:59 AM
E55 KEV's Avatar
Veteran: Air Force
The US E320 for 1996 and 1997 is a straight 6 cylinder engine. Wonder why the mid muffler has dual inlets on a I6?
Old Nov 21, 2004 | 10:03 AM
Whitey's Avatar
98 W210 Advantgarde
Ooops, mine is a late 98 V6......my bad - only one way to check, look under the car
Old Nov 21, 2004 | 07:29 PM
E-Klasse's Avatar
W205 C300
Maybe because there are 2 exhaust manifolds on the engine followed by 2 cats.
Old Nov 22, 2004 | 11:53 AM
Shane C's Avatar
E320
do I have to remove the inpact strips on the rear bumber to remove it? anyone with step by step? I searched here and mbnz and no luck for rear bumper
Old Jan 18, 2005 | 12:00 PM
Ben'z's Avatar
E320
Hi,
Have you installed it?
Ben
Old Jan 18, 2005 | 04:10 PM
Shane C's Avatar
E320
Yep! old muffler and mid muffler removed and amg muffler bolted on and welded in its place R&R $80.00
Old Jan 18, 2005 | 10:13 PM
sbarsap's Avatar
13 Lunar Blue GL550, 06 Imola Red BMW X5 4.8is, 04 Gold Honda Ody
Hi Shane,
Did you have to cut your bumper to install the muffler?
