Bleeding brakes with a Motive Bleeder?
(BTW, is this done as part of the A or B services?)
Is there anything special I should look out for when bleeding the brakes. I've got a Motive Bleeder, and I've used it on another car before without problems.
Any brake fluid recommendations?
Thanks!
As for brake fluid, Mercedes OEM Dot 4+ or Motul RBF600 is what I would recommend.
Merecedes will do a brake flush/bleed as part of the A/B service if you car has been in service over 2 years, then every 48 months thereafter.
On a side note, even if it did stain, who cares? As long as there is fresh moisture free fluid in there, I don't care if it's purple with pink polka dots inside the reservoir!
