light on climate control out
Old Dec 3, 2004 | 02:33 PM
007's Avatar
007
everything does not light up on the climate control module which has the heat and a/c funtions..it still works, just thelight is out, any ideas.
Old Dec 3, 2004 | 02:55 PM
okc329's Avatar
1997 E320 (silver/black)
It has a single bulb to provide lighting
You can easily remove the climate control unit with the two little tools that are also used to remove the radio head unit. It is easy to disconnect the cable(s) from the control unit and then you can replace the tiny bulb mounted in the middle of the backside. Trick is to have the right tools to unlatch the control unit. These can be bought at MB parts department.
Old Dec 3, 2004 | 04:34 PM
diffuzi0n's Avatar
e320 99
I bought them for 10 dollars and it is universal for all benzes
