E50 AMG electrics / door module question
I'd like to try the old right rear door module swap, my question is, are the modules the same part number across the different models, or am I going to be trying to find an e50 specific module?
https://nemigaparts.com/cat_spares/epc/mercedes/1/
See if you can find the service manual here:
https://charm.li/Mercedes%20Benz/
The car has an aftermarket radio in it when I bought it, I have removed this and wired back the original unit. I have also changed the starter motor and rewires the radiator fan. I have looked for loose grounds, no luck, checked the battery and alternator terminals, all good. What I have not done is disconnect each door module one by one or changed the centre console window block. If I'm going to tear apart each door card, the modules are cheap enough that I'd rather have them on hand. I don't know if the e50 has the same part numbers for those modules as other models as there is limited info about e50s online, hence coming here.
For all your correct parts look here---Mercedes / Car > Mercedes EPC Online > nemigaparts.com
There's a lot of owners of early 210s out there experiencing similar problems, so insight on their experience and if the cluster / interior electrics are related in an unexpected way is helpful in narrowing down the issues I'm having on a car that has had some questionable repairs prior to my ownership.
I'll go through the catalogue to cross reference the part numbers on modules etc as required, so good for something then.
Open to others in the community who may be able to shed some light on the issue and if they have successfully resolved them previously.
Like Plutoe said, you need more details. I would hazard a guess most of the failed modules will show something along the lines of "failed network interface". Somewhere, there will be a module that shows "module failed". You have to dig for it. One module will cause a cascade of failures affecting the entire system.
My guess? A failed module is killing the network bus. Where is the junction block? I don't know. What are the network voltages? I don't know. You are going to have to figure that out. The engineers who designed and built this are retired and probably dead. Gonna be difficult to obtain information from them so you need to begin to recreate it. I hope you were able to download a manual for your car that has those values.
See the two following links for suggestions on troubleshooting but be advised the links are for the DAS3 system implemented 03/97. They will not apply to your vehicle but may point you in the right direction. You have a previous version; either DAS2, DAS2a, or DAS2b. Unfortunately, the attached document does not provide voltage values which would be invaluable in troubleshooting your car's network. Be advised, one bad module can and will kill the entire network. Find the module, disconnect it, then deal with the repercussions (will the window ever roll down and up again?)
https://mbworld.org/forums/e-class-w...is-repair.html
https://mbworld.org/forums/e-class-w...-part-2-a.html
Take lots of notes and photos and post them here so others can learn from your efforts.
