View Poll Results: How much oil does your engine consume?
1 qt / 1000 mi
1
4.55%
1 qt / 2000 mi
1
4.55%
1 qt / 3000 mi
0
0%
1 qt / 4000 mi
2
9.09%
1 qt / 5000+ mi
0
0%
No measurable oil consumption
18
81.82%
Voters: 22. You may not vote on this poll
Oil Consumption Poll
Old Dec 12, 2004 | 05:59 PM
lexrex's Avatar
'98 E320 4Matic, '85 380SL
For those of you with the 98+ V6 & V8 motors, how much oil does your engine consume?
My 98 E320 appears to use about a quart (approx 1 L) every 4,000 miles (6 400 km).
Old Dec 16, 2004 | 11:55 PM
Michael Pietrzy's Avatar
1997 E 420
have 97 e 420 4.2 v8 84k miles, i change the oil about 3 to 4k miles and no noticable loss, but 1 liter in 4k not that bad. are you burning, laeking or do you get a puff on cold starts? valve seals?
Old Dec 17, 2004 | 02:19 PM
lexrex's Avatar
less oil consumption than i thought
Since I posted this poll, I've decided that the car is using less oil than I thought. I've only had the car for about a month and put 3,000 miles on it. It looks like it's consumed about 1/2 a quart in this time...that's 1 qt / 6000 miles. Absolutely no leaks, and I haven't observed any smoking at any time.
The oil was changed at most a couple hundred miles before I purchased it. When I picked up the car, the oil was down about 1/2 a quart. When I checked it after 1500 miles, it was down about a quart. I added 1/2 a quart to bring it up to the level where I purchased it. From that, I concluded that it was using a quart every 3,000.
As time goes on, it seems like the variation was caused by temperature. I've noticed that when I check the oil warm, about 20-30 minutes after shutting the engine off, it reads about 1/2 a quart higher than when cold (about 25 degrees Fahrenheit).
So I've decided it's using somewhere between 1 qt / 6000 mi and none at all, which I think is perfectly reasonable for a car with 106k mi on it.
I'm going to change the oil with Mobil1 0W-40 at 4-5k mi and I'll see how it goes from there.
Old Jan 15, 2005 | 07:49 AM
ccmbduong's Avatar
Oil
I use Mobil 1 and change every 10K miles. It's a '96 E320, never uses any oil , even before I switched to Mobli 1., maybe I am a lucky one?
