Engine Cleaner
Old Dec 15, 2004 | 03:52 PM
E320Star's Avatar
2000 E320 Sedan
Lightbulb Engine Cleaner
Does anyone have a recommendation what to clean the engine with on the outside? I am think of using WD-40 to cleanup the engine surface. Any thoughts?
Old Dec 16, 2004 | 09:48 AM
E320Star's Avatar
2000 E320 Sedan
I tried it on my Toyota, looks great. Any suggestions?
Old Dec 16, 2004 | 10:06 AM
Whitey's Avatar
98 W210 Advantgarde
Why not? And it should bring the shiney black back to the plastic engine cover......P.S. I've not tried but I think that's what the used car dealers use to clean up their cars.
Old Dec 16, 2004 | 10:11 AM
michakaveli's Avatar
E300
I recall reading somewhere that using the tire foam stuff works best....
Old Dec 16, 2004 | 10:57 AM
vinceC's Avatar
2014 ML350 4Matic
P21S Total Auto Wash. It is a citrus degreaser. The best! Aluminum looks fantastic after cleaning with P21S! I mix the straight P21S 50% with water and spray it on with a spray bottle. Agitate with a soft brush if necessary. WD-40 colletcts dirt. It can be useful to soften hard grease/dirt if you let it soak, then follow with P21S. One caution - be careful. Try to keep large amounts of water off the wiring and connectors. With all the modern electronics in these cars, a shorted connector can create havoc.
Old Dec 16, 2004 | 11:49 AM
E320Star's Avatar
2000 E320 Sedan
Thank you. I will take it under advisement.
Old Dec 17, 2004 | 01:49 AM
BenzVince's Avatar
09' E350, 01' Maxima SE, 93 Nissan Maxima SE, 1987 Nissan Maxima SE
I would use Simple Green. They work wonders, they do a heck of a good job with the grease removal. The best of all, they are enviromentially friendly and biodegradable.
Old Dec 17, 2004 | 10:41 AM
E320Star's Avatar
2000 E320 Sedan
Will try it. Thank u
Old Dec 17, 2004 | 11:53 AM
Shane C's Avatar
E320
Ha Ha Ha yeah this is good stuff my mom uses it to clean freakin everything!
Old Dec 17, 2004 | 12:27 PM
E320Star's Avatar
2000 E320 Sedan
Maybe i should do nothing then !!
Old Dec 17, 2004 | 05:51 PM
stemags's Avatar
2014 E550 4matic,, sold 2012 E 350 4matic,,sold 2010 e350 4w,sold 2002 e320 se
Vince C has the right idea,,P21s total wash works well,,,also Meguires has a good all purpose cleaner.
Old Dec 17, 2004 | 11:26 PM
Michael Pietrzy's Avatar
1997 E 420
where do you get that p21s? and does it have a brand name or is that it?Want to try on the alum. clean it up . Thanks
Old Dec 18, 2004 | 06:54 AM
stemags's Avatar
Go to properautocare.com,,,or detailersparadise.com,or do a search for p21s,,,you'll find it.I use all their stuff,,,great results.
