Problems with the clock spring
Old Mar 29, 2026 | 08:47 AM
ensio_korhonen's Avatar
W210 E300 D
Hi,
My horn button does not work on my ’96 E300D. I pulled the horns to check them; they are good. The fuse is good, as are all the other ones. I’m guessing its the clock spring. Checked the two horn wires and they get no continuity. Another clue indicating this is that at one point for a few minutes the horns started sounding if I turned the steering wheel. I pulled the steering wheel and airbag and I’ve gotten to the clock spring. Problem is, it doesn’t look like the rear connector wires that go into the clock spring can come off so I can’t remove or replace the clock spring. Am I missing something or do I have to remove the whole steering column to get it off?
Thanks in advance.
Old Mar 30, 2026 | 09:50 AM
streborx's Avatar
Top Answer: 1
G550
Is the clockspring physically damaged or are the contact points just corroded? If the latter, you can try using contact cleaner on them.
Old Mar 31, 2026 | 05:32 AM
W210 E300 D
I figured it out. Just had to pull the underdash and the connectors were there. The clock spring is broken; the wire in the contact cable near one of the connectors has managed to roll up backwards INSIDE the cable so it doesn’t hold current anymore. Might try soldering it back but I’m pretty sure it’s time for a replacement
