Proper Engine Temp
Old Dec 27, 2004 | 11:55 PM
Alfa Fan's Avatar
'07 CLK 350 Coupe, '03 E500 Sport;'02 E320 4Matic; ,08 Jaguar XJ; 10 E350 '65 Alfa Giulia Sprint GT
Proper Engine Temp
The weather in NJ has been averaging around 15-30 F for the last few days. The heater never seems to get very warm and I notice the water temp guage reads around 60C. I've done a search and everyone seems to say that normal operating temp is around 80C. I just had the 60K mile service done. Could I have a wrong thermostat in place?
Old Dec 28, 2004 | 03:29 AM
jemmy's Avatar
99' E320
the proper engine temp is around 90 and less than 100
it is normal that the temp goes higher than 90 when you pump up the engine for a big run but then it should go back to normal again which is 90c soon.
in the case you are having right now, you might wanna get your thermostat checked for any open-failure.
Old Dec 28, 2004 | 10:15 AM
E320Star's Avatar
2000 E320 Sedan
I agree with the 90 and less. Usually mine operates at 80 - 81. I would go back to the dealer and indictae what the is issue is.
Old Dec 28, 2004 | 10:29 AM
Southern's Avatar
1998 E320
With the cold temperatures you are experiencing, it takes more time for the engine to reach operating temperature (around 82 Deg. C). With 12 Deg. F temperatures last week in Chicago it took 20 minutes of driving for my car to reach operating temperature.
Old Dec 29, 2004 | 12:04 PM
jemmy's Avatar
99' E320
yeap, it also depends on the wether you are having ... it might takes longer to get the ideal temp in the cold day and vice versa.
Old Jan 2, 2005 | 11:33 PM
Alfa Fan's Avatar
The temp has warmed up considerably but the temp guage never goes above 60 even after 30 minutes or more of driving. The heat never comes out really hot even when on HI. It does sound like the thermostat may be open. I'm going back to the dealer ASAP to get it checked.
Thanks for the feedback.
Old Mar 23, 2005 | 03:26 PM
E320Star's Avatar
2000 E320 Sedan
According to my manual, depending on outside temp and stop & go, temp may get close to the red zone, but not in the red zone. The red zone indicates an issue and your collant light should come out. These cars will flag a warning when something is wrong.
Old Mar 23, 2005 | 10:46 PM
Green E-300 DT's Avatar
Late Built 2005 W-211 E-320 CDI
Question Wow!
Does the word failed thermostat come to mind?
Old Mar 27, 2005 | 08:10 AM
Helmut430's Avatar
2020 S Cabriolet, 2014 SL63, 2002 SL500
not that I know a lot about the situation you are having, but too much anti freeze in the mix will keep the car from warming up to temperature as well,,, had that happen to me a few years back. But, does sound more like a thermostat problem
