passanger side mirror
Have you ever re-attached the glass part before?
There should be a hook and slot connection system on the bottom. Across the top there should be a single wire spring that attached to the mirror and then loops over the motor mount.
P.S.
When you pop that spring holding the housing in place make sure you bend it back slightly afterwards. That way the housing will snap back on tight again.
