Roll Call! How many miles on your car now?
Old Aug 3, 2007 | 08:56 AM
  #51
citruspilot's Avatar
06 CLS500, 04 Tahoe, 04 Infiniti G35 Sedan, Boeing 737
159,250 on my 97 E420..............
Jeff
Old Aug 4, 2007 | 02:53 PM
  #52
dn54168's Avatar
99' E320 62,000+ miles & counting
My 99 w210 is 56,XXX.
I only have had 4 problem so far,
1. Door will lock itself. Fixed with new wiring harness.
2. The seat sensor was broken so the airbag was disable. Fixed with the change of new sensor.
3. The motor in the head rest on the driver side was broken.
4. The radio reception is terrible. Will have a new power antenna install the coming Wed.
Fixed up w/
1. Nakamichi CD-400 head unit.
2. Rues System design by Rick Rues (Just pick it up today, the cleanest sounding system ever.)
3. The Goodyear Eagle F1 directional Summer Tire. (Dam, this tire is sticky)
Thing left to be done,
1. Window Tinting.
2. A set of new wheel (maybe).
3. Bi-Annual car detailing.
Old Aug 4, 2007 | 04:06 PM
  #53
Green E-300 DT's Avatar
Late Built 2005 W-211 E-320 CDI
Question Radio Problems?
Thing left to be done . . Window Tinting.
Before you go to that expense, check IF the connections around the ant. amplifier are not loose or dirty.
That's all that was wrong on both the daughters' '97 E-420 and my '99 E-300DT. This is quite common BTW.
Regarding window tinting . . that can raise hell with radio reception IF not done properly. Be careful.
Old Aug 14, 2007 | 11:21 PM
  #54
foreyes's Avatar
2002 G500, 2007 CLS 550, 2018 GLC 300
195k on 97 E420
195k on my 97 E420, still runs flawlessly, have only purchased oil changes, tires and brake pads in the last 40k. It still clocks a 6.9 second rolling start from 5-60! The only mods are AMG Monoblock 17x8 3-piece wheels, Eibach springs and KYB shocks.
[IMG]<img src="http://img362.imageshack.us/img362/4676/dsc04451hh5.jpg"
Old Aug 14, 2007 | 11:41 PM
  #55
michakaveli's Avatar
E300
Nice to see you are taking care of her and it shows! The car still looks like new...
Old Aug 15, 2007 | 12:17 AM
  #56
victorylap's Avatar
2000 E320, 2007 Land Rover LR3 HSE, 2008 E350
Just around the corner at 87k and still running smooth and strong!
Old Aug 15, 2007 | 06:55 AM
  #57
43fatman's Avatar
2001 E430 Sport
115,xxx-2001 430.
Old Aug 16, 2007 | 02:58 PM
  #58
EclassQC's Avatar
E320 2000, E350 2008, 911, Civic
115,000 on a 2000 E320
115,000 on a 2000 E320; a faithful and very dependable car with extremely good 'stately' looks.
[a] Main repairs:
[a1] under warranty: thermostat, dashboard lamps, key FOB, sensors at 100; RHS rear window regulator at 35,000; exhaust at 45,000. I had an extended warranty.
[a2] out of pocket: vanity mirrors at 100 then 5,000-etc. replace plastic hinges with nails; MAF and O2 at 75,000; rotors & rubber coupling at 85,000
[a3] never worked: TeleAid; there seems to be conflicts at the antenna switch between the analog cell the analog TeleAid transceiver
[a4] working erratically and not replaced: LCD for temperature, clock and shift; they started to loose pixels within 3 years under warranty, but then MBUSA 'could not duplicate the problem' and I did not spend the $800 to replace the LCD. Backlight lamps had died a few times and were replaced. Note that the main LCD never had any problem, except with its backlight lamps.
[b] Remaining issue: gremlins in the electrical feed of the LHS main beam; LHS lamps dies every six months or so, while RHS has only been replaced once. It seems that there are high voltage spikes in that circuit. Forensic also shows that LHS socket burns every six months, reducing it to black charcoal dust and letting the wires loose; this might explain some E320 engine fires. After replacing with MBUSA sockets twice, I finally used aircraft-grade sockets. I warned MBUSA about the problem. I believe that the dashboard lamps are on the same system, because I have to change these non-stop.
[c] I purchased the car at night: bid mistakes as there were numerous cosmetic and accessories flaws: so much for MBUSA quality control in 2000. The car looks better now than ever.
Old Aug 16, 2007 | 08:11 PM
  #59
gqmagic's Avatar
96 SL500, 97 E420
1997 E420 bought in April '05 had 35k miles, now has 66k miles.
Old Aug 17, 2007 | 06:49 PM
  #60
dukeblue91's Avatar
1997 E320 W210
142K on my 97 E320
And she is as tight as a new one.
Old Aug 22, 2007 | 08:39 PM
  #61
tmaguire's Avatar
2005 CL55 AMG, 2004 S430 4matic, 1988 560SL, PRIOR: 2000 E430 4matic, 1994 E320 Coupe, 1999 C43 AMG
2000 E430 4matic
149,234 and still going strong
Old Aug 22, 2007 | 10:09 PM
  #62
ProV1's Avatar
MB, BMW
q for those with 120K+ miles:
did u flush out the ATF & rear diff fluid regularly? or not?
Old Aug 22, 2007 | 11:07 PM
  #63
cmeblaisen's Avatar
Roll call
2000 E320 4Matic With 64 K on it and still running strong.
Attached Thumbnails Roll Call!  How many miles on your car now?-mercedessidepasssmall.bmp
Old Aug 22, 2007 | 11:17 PM
  #64
okc329's Avatar
1997 E320 (silver/black)
105,000 on '97 E320. It runs better and rides better than ever and has been relatively trouble-free since 50,000 miles. Had transmission service at 80,000 including drain of torque converter.
Old Aug 23, 2007 | 11:48 PM
  #65
gasoel's Avatar
2012 E350 - P2, 08 E350 AMG Sport, . 96 E300D 230+k. 03 Limited 4xSequoia & 2011 Volvo C30 R design
169,000 on 96 e300d
Old Aug 26, 2007 | 06:26 PM
  #66
abs's Avatar
abs
Ive go 340,000 on my 2000 e300 td! no major problems apart from the gearbox.
Old Aug 27, 2007 | 05:14 PM
  #67
4matic's Avatar
04 S430 4Matic/03 Ml 320/ 98' E320 4matic/ 73' slc 450/ 05 cherokee
166900
166900 on my 98'
Old Aug 27, 2007 | 06:21 PM
  #68
jjay911's Avatar
1991 300sl 5 speed manual
Im itching to buy a 99 turbo diesel if anyone knows of one. Selling my collection.. JJ
Old Aug 30, 2007 | 04:55 PM
  #69
300TD's Avatar
Hi
1998 E300TD Wagon 256000 miles and counting. Still doing approx 3000 miles a month.
300TD
Attached Thumbnails Roll Call!  How many miles on your car now?-car-pics-091-small-.jpg
Old Sep 1, 2007 | 11:11 PM
  #70
dkmeth's Avatar
1994 C280, 1997 E420 Sport
205XXXon my 1994 C280 and still as good as new
134600 on my 1997 E420 with a few problems
Old Sep 2, 2007 | 12:39 PM
  #71
Max Hughes's Avatar
38K on the 1997 e320- gas gauge is out and no other problems
184K on the 1986 300e and ive only broke a valve spring and the fuel relay.
Old Sep 4, 2007 | 12:09 AM
  #72
cragigotgame's Avatar
97 E420 90 300E
189,000
Old Sep 4, 2007 | 08:22 AM
  #73
John Mackey's Avatar
E200K W210
W210 E 200k
Just turned 300k Kilometers on '00 reg E 200k, running well, no oil consumption, no rust, few nigly things like temp and clock displays have faded away, ESP/BAS warning shown now and again but cancels on switching off and on ignition.
Old Sep 4, 2007 | 11:10 AM
  #74
alpe320's Avatar
1999 E320
64.5k on '99 E320
Allan
Old Sep 6, 2007 | 09:20 PM
  #75
99MBSport's Avatar
1999 C280 Sport
90,000 on my 1999 C280 Sport
