New goodies in my ride..
Old Jan 11, 2005 | 12:43 AM
carlsson9's Avatar
Mercedes W210 E280
Hey all..
Just got my car back from a usual service ( oil and flushing gear box oil, filters, etc) and decided to put in some added stuff..
tyres were gone (Yoko's AV100s), so I've gotten dunlop's new Direzza DZ101 from Japan. Can't compared it to the Euro tyres, but i got it cheap with new techonology, so hoping it will last well..so far I'm just riding in the tyres, but its been good..
Blistein Yellow shocks! Now this really makes a difference for the car! I've used back the avantgarde springs, and it flies at corners..corners i usually do 80km/h before felt like the car was wobbling and shakey a bit, but with the bilstein, I'm doing 110km/h at the same corner, and it feels solid . The ride has also improved..softer, comfortable ride..I thought changing shocks wouldn't make a diff, but man, it sure feels good! recommended to all!
problem with my ETS/ABS light coming on was fixed by changing a stop light swicth ( US25 ), problem has gone away like the dodo.
brake discs for the front were gone too, so had to change those, and skimmed the rear, but will probably change them next time...still waiting for them brembos..:P
hopefully will take some nice pics once I've sorted the paintworks..
Old Jan 11, 2005 | 06:55 AM
LorinserLV2's Avatar
96´E280 6.cyl
Good news
Check if Black Diamond has disks for our car. I´ve put a set of these on my race Toyota Corolla just slotted working with Ferodo DS3000 and it´s braking is phenomenal.
Im using ATE powerdisks, but im not very happy with them, they make alot of noise and can t handle well the Ferodo DS2500 im using....I would rather prefer the OEM disks to these ATE im using.
Laters
Old Jan 11, 2005 | 12:23 PM
sbarsap's Avatar
13 Lunar Blue GL550, 06 Imola Red BMW X5 4.8is, 04 Gold Honda Ody
carlsson9 which Bilstein shocks did you use? HD's or SP's?
Old Jan 11, 2005 | 02:10 PM
Whitey's Avatar
98 W210 Advantgarde
Originally Posted by LorinserLV2
Good news
Laters
Black Diamond does have an application for our E's, I'd almost put a set on when I found some Brembo Max's
which are much cheaper, saving me $$$$ for a set of steel braided brake hoses....the result was Some noise initially but that was probably cuz I'd used the old pads, after they were worn in it was all quiet again
Old Jan 11, 2005 | 02:33 PM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Originally Posted by carlsson9
Hey all..
Sounds great! You should hurry up with the pics. though mang!:p Anyway, what kind of springs are you on???
Old Jan 11, 2005 | 04:09 PM
96´E280 6.cyl
Whitey:
Do you recommend the Max ones?
Where did you get the SS brake hoses? And also which brake fuild youre using?
Old Jan 11, 2005 | 06:16 PM
MBZ12's Avatar
'07 R350. '05 C230. '93 454SS Truck. '71 Chevelle SS.
Whitey....how much does a set of those Brembo Max rotors run??? And stupid question....do the rotos maintain their "black" color as they wear??? Are they coated black?
Old Jan 11, 2005 | 07:38 PM
96´E280 6.cyl
MBZ12 , they will probably worn out and get the normal disk color as being used.
The ones i have on my Toyota were just like those Brembos and theyre getting the normal color where the pad brakes :P
Old Jan 11, 2005 | 08:40 PM
Whitey's Avatar
98 W210 Advantgarde
The Diamond blacks are remarkable, with a choice of slotted, drilled and combo but at almost double the price of the Max's (the Max's cost about 10-20% more than the OEM rotors, if that's any indication of price), I preferred to save up for another mod They work just fine for me, much better than OEM - I would recommend them based on value for money alone. I don't think they have an application for anything larger than an E320, but I may be wrong.
LorinserLV2, I bought the Max's in HK, as with the SS hoses - had an earlier post with all the details. I'm not sure what my mech uses for the fluid but I would assume the original stuff as he would prefer to use OEM products for consumables.
Yes, the Max's do wear out to the bare steel color. Mine were actually greyish when new, not the black pictured (they come in two different colors). The idea is that there will be protection from corrosion where the pads aren't in contact i.e. not a cosmetic feature. One of the slots are supposed to wear out completely to indicate wear too (my other post has a link to a US site I think).
Old Jan 11, 2005 | 09:31 PM
Richard Galing's Avatar
W210, W220, W163, W164, C6
Hey Karlson,
Like Jimmy said, let's see some snap shots
Great to hear your having too much fun
Old Jan 11, 2005 | 09:45 PM
Whitey's Avatar
98 W210 Advantgarde
I thought you had a Classic or Elegance - how come you've got Advantgarde springs?
What's wrong with your paintwork? Hope it gets fixed soon.
Sorry to hijack your thread again Karlsson.....:v
Old Jan 12, 2005 | 12:50 AM
carlsson9's Avatar
Mercedes W210 E280
Hahhaa..no worries Davo...
changed to the avantgarde 2 years ago when i swapped my 16s to 18s...tried KWs at first but it was too low, the avantgarde gave me a nice low height, but not too low for our lousy pot hole ridden country!
they guy that fixed my bodykit did a lousy job ( dots here and there, and one hell of a lousy polish job ). He admitted it and told me to bring it back when I was free, coz i was rushing them to finish the job as i needed the car...anyways, hoping to get it done soon, and get the fron avantgarde grille sprayed too..
Old Jan 12, 2005 | 12:54 AM
carlsson9's Avatar
Mercedes W210 E280
I think its SPs ( sports ? ) ..the yellow coloured one..
I heard it would do wonders with eibach springs ( or others ) but since my avantgarde springs are only 2 years old, I thought of just keeping it..
Old Jan 12, 2005 | 12:57 AM
carlsson9's Avatar
Mercedes W210 E280
in process! can't get a nice backdrop to shoot the car..plus, it rained and its all muddy from my visits to some construction sites..
jimmy, springs are original merc avantagarde..
richard, never thought driving at corners would be so much fun ( especially in a benz! )
Old Jan 12, 2005 | 01:33 AM
Whitey's Avatar
98 W210 Advantgarde
hahahaha, culd have given you my advantgarde springs 2 years ago
