Brake Pad Replacement
My .02$,,I would go Brembo,drilled,red calipers,maybe yellow.
Whitey knows I have the paint for it
Good luck and postem pics.
Front: 316mm
Rear: 290mm
The only place I could find the fronts in drilled 316mm's are on www.brakeworld.com but they sell rotors made by DiscItalia, which is a brand I don't know much about.
Another option I am looking at is the C32 Brake Kit which isn't that costly compared to the other BBK's.
I also came across this thread on another Benz Forum, sounds like another option for our W210's. I am awaiting the member to post more details:
http://www.mbnz.org/forums/forums/th...&posts=8&fid=6
I will keep you posted.
Good Luck.
! Just get the C32 brakes, they're nice and imo give you the best value for your buck, by a long shot, compared to the other BBKs. With E55 ones the possibility of needing a change of wheel in most cases (unless you have AMGs) is more likely and the W210 E55 brakes aren't drilled like the C32.
