Does Your A/C Do This?
Old Jan 22, 2005 | 01:39 PM
Whitey's Avatar
98 W210 Advantgarde
OK, it maybe in the manual but I don't have it handy.
I've never noticed this because the weather has never been as cold here before but recently I've had to turn up the temperature of my AC higher than normal (to 70F+), running on "ECO" (i.e. no AC) and on "Auto" mode. I noticed with a warmer setting, the air flow from the center outlets was greatly reduced (almost none) and the ones on the side became much stronger. At first I thought "WTF, not another computer problem again???!!!" but when I pressed the AC button, and set a lower temp, the air started streaming thru the center vents again and the ones on the sides became much weaker (which was a problem I've experienced in summer ever since I got my car.....). Can anyone confirm whether this is normal, perhaps a feature of the "auto" mode? Many thanx.
Old Jan 22, 2005 | 10:47 PM
livetodrive's Avatar
2001 E-430 4-Matic
No Heat Out of Center Vents
Regardless of the register settings, the center vents only deliver air in the air conditioning mode. They will not open in Heat mode.
Old Jan 23, 2005 | 03:26 AM
why_not's Avatar
W212 2009, W115 Pullman & EQC
Well its cold mere in Denmark these days..
And my 96 does the same thing.. in auto & no a/c
When the car starts to warm up.. no hot air from center outlets.
When the car has warmed up.. the airflow begins from the center..
/kim
Old Jan 23, 2005 | 05:47 AM
DesertSilver22's Avatar
2000 E320
I wouldn't worry about it, i think that's normal mine does the same thing too. I have two friends with W210 and theirs also does the same thing.
Old Jan 23, 2005 | 06:15 AM
Whitey's Avatar
98 W210 Advantgarde
Thanks guys, that's comforting to know.
It is however, baffling as to why it does that, maybe its something to do with MB seeng the need to defrost the windows first whilst the passengers freeze to death (or the way hot air flows vs cold air?)
Old Jan 24, 2005 | 10:12 AM
E320Star's Avatar
2000 E320 Sedan
Mine does the same thing too. It is normal. If still want it fixed, you may want to buy a Cadilac STS 2005. Wonderful car I tellya
Old Jan 24, 2005 | 10:44 AM
Whitey's Avatar
98 W210 Advantgarde
Granted the STS is a beautiful looking car, it doesn't make sense to change just because one can't figure out how to live with a bizarre A/C design In any case, it is still relatively new and maybe not all the bugs have emerged yet....might have to give it a couple of years but then again, I'll probably opt for a CLS or S maybe if I were ever to go down that route
Old Jan 24, 2005 | 01:33 PM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Yup, mine did the same thing...don't know why they did this???
Old Jan 25, 2005 | 08:29 AM
Whitey's Avatar
98 W210 Advantgarde
Hey, wassup Jimmyboy? I'm guessing its a feature to help defrost the windows first but one would think surely not at the temps I'm using....
