Going to pick these tail lights up today, question about install
98 W210 Advantgarde
Asuming your's are replicas, they MAY fit without a mod. Try mounting the center ones (these are the only ones that need modding) inside the recess in the panel first, if they sit flat with the panel, you won't need to trim it down.
98 W210 Advantgarde
Are those replicas or OEM? (OEMs will have a tiny MB star logo on the red suface of the lense (somewhere)). Anyway, sounds like they were "meant to" fit since the original ones are quite a way off - not close. Anyway, shaving should do it...but if not OEM, I'd suggest double checking where the lights need shaving first as they may not be the same place as the OEM ones.
when i checked the only place that didnt seem to fit perfect was the place you outlined, im pretty sure their replica, but it wasnt very far off, maybe i should try and give it a little bit more of a shove. the real reason im asking is what bit to use for my dremel, a cutting circular bit, a grinding bit, etc.
'04 Silverado Z71 - sold all my Benzes and need another!
#34
alright got it all finished, it looks so much better with these lights, the only thing is that im getting a "lamp defective" error message, but both brake lights work, both turn signals work and the fog light works. anyone out there have a suggestion of what to check?
#35
S, GL, Escalade ESV, my shoes
1. Two little bulb on top of license plate.
2. Reverse light
3. Third brake light
4. Rear driving light (turn on/off along w/ your headlight)
2. Reverse light
#37
so i took them over to my local mercedes specialist and he finds that the reason the outter (brake lights) dont work is because the metal board are warped on the lights, what a ****ing hassle, now i have to drive back out to west la, next week, cause they dont have any in right now, and get a new set out outter lights.
it will probably look stupid but im going to run the centers with the original outter tails
#38
I have a set of 2001 outter light. in pretty much new condition. If you're interested, we can work out a deal.
Prefer SoCal local pick-up, it's PITA to ship these things
#39
98 W210 Advantgarde
#40
thanks
#41
Red & clear, just as you see in 2001 E320/430
are they the smoked version? if so lemme know im socal local and could easily drive and pick them up, lemme know
thanks
thanks
#44
98 W210 Advantgarde
how much are you looking for?
#45
Won't look as nice as original red & smoke. Try to call phil at FastLane
hmm, i wonder if i could get the tops smoked to match the center lights i still have in.
#46
I'm doind the same thing to my 97 e420 and I think I'll get them from the same people did they ever fix your problem???? Zam do you still have those original lights I havebt bought mine yet and I'm very interested.
