E-Class (W211) 2003-2009
dvd burning help
Old Mar 29, 2005 | 01:07 PM
jago1244's Avatar
2016 G63 ; 981 boxster GTS
dvd burning help
ok i have been curious to see if my MY05 comand will accept mp3 dvds.
since i have no access to pre burned dvds and i have a bunch of music on my hard drive, i searched the threads and came to the conclusion i could burn audio dvd's using nero software.
any help here would be appreciated..tia.
i have dell pc about 2 yrs old, 1.8 ghz, running xp pro.
purchased a maddog 16x external dvd burner with nero oem 6 software
my usb port is 1.1 , not 2.0
used sony 4x compatible discs.
loaded about 4g of music files, folders by artist, and then subfolders by album, from about 50 or so encoded cd's. i didnt try wma files that i have from napster nor indiv mp3 files from a phatnoise library.
the folders loaded up into the nero app in about 11 mins, then the 'burning process' was begun. the app sat there at the 1% level for at least 30 mins.
after aborting, i even uninstalled and reinstalled all software and hardware and redid the whole process and the same result. before i pack this box up and get a refund, is it that my equip is inadequate to the task? or other issue? has anyone been successful with similar setup? thanks for any comments.
j.
Old Mar 29, 2005 | 04:05 PM
Miguk_Saram's Avatar
'07 GL450
j.
You seem to be on the right track (no pun intended).
If Nero is hanging, then it's probably trying to read all of the files prior to burining them, which points to a memory problem (not enough of it), or a processor problem (not fast enough swapping info to/from memory), or a combination of both.
I suggest you attempt to burn a smaller amount of info to a DVD first, say, 1gig (maybe less), just to be certain that you are ABLE to burn a DVD MP3. If you are able to burn a smaller amount of data, then Memory is definately your problem.
You can trying playing with your "Virtual Memory" settings under [My Computer], [Properties], [Advanced], [Performance, Settings], [Advanced], [Virtual Memory, Change]. Also, make sure you have enough free disk space, if you're burning 4gigs, it'll probably help to have an EXTRA 4gigs available on the drive where the files are.
Also, visit the DELL site and upgrade the BIOS (Flash bios) to the latest version for your model PC, earlier BIOS' had issues burning DVDs.
Finally (perhaps you should do this first), ensure that your hardware is compatibe with the software (NERO) and that you're running the latest available version of your the product; while you're at it, ensure that you have the latest Microsoft patches installed (many software vendors "fix" bugs in their products which often times are hardware specific).
The best thing you could probably do though, is get more memory.
GL.
Old Mar 29, 2005 | 04:57 PM
gohorns44's Avatar
Also, this may sound a bit rudimentary, but check to see if you are using the correct format of DVD disk for your burner. Are you using DVD -R or +R or possibly R/W?
I've used Nero in the past and it hung at this step when I put the incorrect media in the burner.
Good luck
Old Mar 30, 2005 | 08:58 AM
jago1244's Avatar
thanks guys
thanks for the responses.
miguk i will follow your advice.
gohorns i used dvd-r. the maddog burner takes all those types i believe.
i'll try again over the w/e and report back.
thanks , j.
Old Mar 30, 2005 | 01:11 PM
steph280's Avatar
Tesla
I'd be curious to see if anybody with an 05 can get the COMAND to play DVD mp3's. So far I have yet to create a DVD recognizable by my COMAND. Have tried DVD-R, +R, and +RW. CDRs works just fine though so it's not my burning technique.
Old Mar 30, 2005 | 02:43 PM
weinschela's Avatar
'14 E350 wagon; BMW G12 (2020) G01 (2019)
I play mp3s in an 05 E500 and an 04 E320. I burn them with Nero 6. The trick is to make data discs not mp3 discs. It is counterintuitive to select data when you know you are copying mp3 files, but this is what works. Each album goes in its own folder, but I have not used subfolders, as I understand it can create problems.
Old Mar 30, 2005 | 06:15 PM
steph280's Avatar
Tesla
I use Nero 6 (not the express) which doesn't have the mp3 option, just standard data file, music, and some other options. I always burn on data file mode, and it has been working fine with CDRs. Only the DVD is not recognizable by COMAND. But these DVD can be read on all my computer and DVD players so I doubt it's anything to do with DVD itself.
I am wondering if not all 2005's have DVD drive in the COMAND?
Old Mar 30, 2005 | 11:21 PM
khaug's Avatar
'05 E320 CDI, '07 VW Touareg V10 TDI, 2007 Porsche GT3
I now have my entire 200 CD collection compressed onto 3 DVDs which play in my Comand's single-disc drive. They work well and sound good.
I did everything with Nero 6 Ultra edition. I first used the "rip CD tracks" utility to convert the CD tracks to MP3 format, using a low-compression setting to preserve sound quality. I then used the Burning ROM utility to make an ISO data disc from the resulting .MP3 files. DVD+, -, R or RW discs should all work.
I have to doubt that your hardware is the primary problem. I've successfully burned DVDs on my second computer, an ancient Dell XPS T500 with a 1.4 GHz Celeron processor, 512 MB of memory and Windows 98 SE. I'd make sure that your Nero can recognize your burner - check their web site for any updates and a list of which software versions recognize which hardware.
I do have to say, though, that it's been my experience that non-mainstream "bargain" brands such as your burner have more than their share of compatibility issues, and the fact that it's an external burner compounds problems you may have. FWIW, I'm currently running a Dell Dimension 8300 w/3.4 GHz processor, 1 GB of memory, a LiteOn internal burner that I installed and XP Pro.
Good luck. Don't give up - it'll be worth it in the end!
Old Mar 31, 2005 | 10:26 AM
CASL55's Avatar
2004 SL55, 2005 E500 Wagon
So am I. I can't get mine to work either. I never get the DVD splash screen, just the CD one. Is that a clue?
Jim
Old Mar 31, 2005 | 10:44 AM
jago1244's Avatar
karl, thanks. the nero app actually came in the box with the burner.
i'll keep working on it..
Old Apr 1, 2005 | 09:56 AM
superflysocal's Avatar
if you just want to know if your car even has a dvd drive, just put a commercial dvd in the drive (any movie). It should play except with sound only, no video and you should get the message that the video has been blocked. If you don't get this, then you probably don't have a dvd drive.
Old Apr 3, 2005 | 10:16 PM
ATS's Avatar
ATS
2004 E500 / 2001 C240
The way to get Roxio to burn a DVD is use a Data disc and select Joilet as the file system (which is not the default). I just tried this tonight and now I am able to burn a DVD disc with Roxio and I was unable to do this prior.
Old Apr 6, 2005 | 12:43 PM
CASL55's Avatar
Finally tried it in my November build E500 wagon. Got the CD logo (no DVD logo), then it spit out the disc. Guess that means there's no DVD drive in my car. What do you mean when you say "probably"?
Jim
Old Jun 12, 2005 | 05:33 AM
OzE55's Avatar
2003 E55
I have an Australian spec (read Euro) 2003 build E55. Its COMAND has a single slot DVD player (movies and audio) and in dash CD changer.
Initially I couldn't play mp3s from CD or DVD.
After interogating the forums I got a software up grade which allows me to play mp3s from a DVD in the DVD slot.
Here's the interesting part - I've just burned 3 DVDs - same brand disc, Nero, same files and folders on each disc, and the first 2 didn't work. One was burned as DVD data and the other as DVD mp3 - both burned at 4 times speed. (I think in ISO but I cannot find that setting - anyway I didn't change it (I've read that some people use joliet setting)). I just burned a disc at 2 times speed and it works perfectly.
I think the player is just fickle and suggest saving the compilation and burning a few discs at different speed etc. Write down what you did for each disc and see how you go. Maybe better media cuts down the waste?
My 2 cents worth.
Old Jun 12, 2005 | 07:52 AM
khaug's Avatar
My 2 cents worth.
Only discs burned as data discs work in my car. Anything else will not work.
Old Jun 14, 2005 | 08:53 PM
pa28pilot's Avatar
'05 E320CDI, 1987 300E, Vanagon Syncro, Turbo Arrow III
I just tried it in my October build E320CDI and had the same experience. I did cram the DVD full though, so perhaps I should try it with a more modest burn before I claim defeat.
In talking with engineers a while ago, I heard there was a "lower cost" COMAND variant. I'm thinking this might be it.
(Apparently MB is quite sensitive about anything being called "low cost", so they may have another name for it, although they do use that term for the redesigned Tele-Aid platform.)
Old Jun 15, 2005 | 04:25 AM
Dema's Avatar
i535
I'd suggest to return the burner and buy an internal one, like nec 3520a
http://www2.newegg.com/Product/Produ...82E16827152035
You can try also to add USB2 card ($11), because USB 1 will definitely issue buffer underrun even on x1 speed. I do not know how Nero+drive can handle that.
