E-Class (W211) 2003-2009
DVD/TV in Motion Help
Old Apr 26, 2005 | 04:58 PM
Quiznos's Avatar
Question DVD/TV in Motion Help
I have a 2005 E500 purchased from the factory owned dealer in Costa Rica. I believe it a European Spec car as it comes with European options and features (like the long license plate spaces).
The car came with the DVD and TV option from the factory. The TV and DVD work great but the picture fades out after about 5mph. I have seen previous posts for 2003 E models, but no clear answers on getting TV or DVD to work while in motion on a 2005 model year car.
Can anyone help with specific instruction on how to enable DVD in Motion on a 2005 model year car?
My Command unit looks like the one pictured.
Thanks in advance for your help!
Attached Thumbnails DVD/TV in Motion Help-dsc00779.jpg
Old Apr 26, 2005 | 05:21 PM
hlkc's Avatar
06 CLS500 + 99 ML320
You need to find someone there with a Mercedes Star Diagnois and all they need to do is disable the 5MPH function.
Thanks,
hlkc
Old Apr 26, 2005 | 05:28 PM
Quiznos's Avatar
Question
As far as I know only the factory owned Dealor has the Star Diagnostics tool and they refuse to do it........I might be able to talk a tech into it if i knew the exact procedure to do it. Does anyone know this?
Alternatively, is there a way to do this without the Star Diagnostic tools?
Any special codes or menus which can be accessed throught the Command unit?
Old Apr 26, 2005 | 05:47 PM
hlkc's Avatar
Quiznos,
Not sure over there but here in US we lucky to have MBenzNL Steve and Schorile and they travel around here and take care of this problem and other Star Diagnostics related problem.
As far as I know there is no way that you can use soft key or any secret codes disable that function.
Cheers,
hlkc
Old Apr 27, 2005 | 03:47 AM
glojo's Avatar
E-class E300e Estate, Sprinter (stretched limo)
Interesting comment. European vehicles are either called Elegance, or Avantgarde depending on specifications. The white dials and maple are only available on the Avantgarde, bi-xeons come also come as standard. The model name is discretely placed in the moulding on the front wing.
There are a few members that go on the warpath at the mention of 'DVD in motion' (moi!!!) so I will not go down that path.
Good luck with your question :v
John
Old Apr 27, 2005 | 02:23 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
1) Most of the european cars HERE are called classic...elegance and avantgarde apparently gets too expensive...
2) bi xenons come standard on the W211 in some european countries...but NOT in most of the european countries.
Back to the DVD in motion enabling: if the comand has the MP3 capable software - your dealer most probably is not able to enable DVD in motion...a slightly modified stardiagnose is required then...
greetingz,
Old Apr 27, 2005 | 02:45 PM
glojo's Avatar
Originally Posted by MBenzNL
1) 2) bi xenons come standard on the W211 in some european countries...but NOT in most of the european countries.
Sorry to stay slightly off topic, but what European W211 Avantgarde does NOT have bi-xeons?
What European country supplies an E500 CLASSIC?
John
Old Apr 27, 2005 | 03:28 PM
MBenzNL's Avatar
some slow@$$diesels
sorry to go even more off topic...but in your first post you were writing about
European vehicles
in general - not about the E500 in particular...sorry for the first off topic
greetingz,
Old May 3, 2005 | 05:51 PM
Quiznos's Avatar
Okay.....Dealer has decided to use the Star Diagnostics try to get DVD to work while in motion (for my passengers of course) as long as i sign a legal release.
Has anyone done this with a 2005 E class with the European head unit (already equipped with both DVD and TV). If so, what is the exact procedure?
Regards,
Old May 3, 2005 | 06:44 PM
hlkc's Avatar
Regards,
Quiznos,
I wonder are you in US? Your dealer should know how to do that. All they need to do is disable one of the function using Star Diagnostics system...
hlkc
Old May 4, 2005 | 04:40 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Originally Posted by hlkc
Quiznos,
hlkc
It's NOT possible for the dealerships to do that with newer software or newer COMANDs.
-s-
Old May 4, 2005 | 09:55 PM
Brav's Avatar
07 M6, 05 Noble, 01 S4, Smart ForTwo
FWIW, I was able to DISable the DVD in motion inadvertently while messing around in some secret menus I had no business being in.. unfortunately, there is no way that I've found to enable it back without Steve.. good thing he will be here this month Right Steve?? When are you coming?
Old May 6, 2005 | 08:01 PM
Quiznos's Avatar
How do you access the secret menus?
