i have a 2004 e320 with the appearance package and premium package. i believe the appearance package has the special tinted windows. i recently had the wind shiled replaced at the dealer but noticed the windshield is clearer than the side windows. i want to make sure they replaced it with the right part. can anyone confirm the part number for me? the one they used as a replacement is 211-670-02-01.
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
thanks.
It's more complex than just "appearance package" or not. It depends if you have a panorama roof. You don't list your location, but we'll assume you are in the US because you write about 'appearance package" and that is used in the US, although it may be used elsewhere as well. If you're in the US, we can eliminate the possibility of head reflecting glass; otherwise, that depends as well.
I think that leaves only 7-8 choices for glass, leaving a dependency on your chassis number.
It makes it slightly easier if you tell us the COLOR of the glass of your side windows; this will narrow it down a bit (cut it in half roughly). If you can't tell, take a piece of white paper and look at it through the glass. Is it blue? Is it green? Is it clear?
i'm located in the US and do not have no pano roof. i cannot confirm the color as i'm away from home right now. can the chasis number be determined from the vin number? the vin is WDBUF65J14A424662.
