Pre-Wire for Sirius Deleted?
I expect to pay a premium for MB parts, etc, but 1K for Sirius?? Does it come with pliers to pick your underwear out of your butt after they bend you over and ram it home? Hmmmm......
If your W211 build date is 06-01-05, that means the chances of your W211 has NOT reached US shores yet. It takes around 60 days to for the car to be built, wait for the ship, then for the ship to load, ferry and clear the VPC.
If your friend's car is an off-the-showroom floor vehicle, then PDI also takes another day-or-two, and showroom prep would be another day or so.
So, how did your friend discover the missing pre-wire by bringing his car to the dealer for a Sirius install?
I thought about it on my present E 320 but the antenna solution was terrible.
So unless you order it, it's effectively a $1000 option.
As far as the prewiring, my understanding is that the true factory installations (on the assembly line) will be done on the C and E sedan without panorama roof. The antenna will be the same small color matching antenna, however it will be mounted on the roof. These cars will not have the prewiring.
For the 211s with panorama roof, they will have the prewiring, since the antenna is mounted on the trunk, as is done now, because there is no way to put the antenna on the roof with the glass roof. For the 07 model year there should be a new roof mounted antenna (shark fin) that will include the sirius antenna along with the gps and teleaid antennas already there.
They are heading down the road of making this factory assembly line only, or should I say not including prewiring. This does have the advantage of being cheaper to do rather than what a dealer would charge.
I'll check tomorrow and let you know for sure.
If I had a job that required me to do a lot of driving, or I had to do a lot of long distance drives it would be a no-brainer and I would even pay the $1000... but I don't do either, and when I'm in the car, I just listen to NPR or the local classical station 90% and 10% CD's... Really for the cost (I'm sure $100 or less), MB should have thrown this one in...
I have XM at home, and a pre-paid 3 year deal, and I can honestly say I haven't used it in weeks.
S Class (220)
CL (215)
CLS (219)
CLK Coupe (C209)
G Class (463)
E Class w/panorama roof (211)
SL (230)
SLK (171)
The factory option code for prewiring is 531, and the VPC installed SIRIUS option is code 022.
The following cars (for model year 06) do not have the prewiring, thus the code for the SIRIUS option on these vehicles is 531.
M Class (164)
C Class (203)
E 500 and E 55 (beginning with July production, the E 350 will have this code too)
CLK Cabrio (A209)
So, what this all means is don't completley fret if you can't tell for sure by the above information. At the end of the day, the last word will be to check and see if the antenna leads are in place on the underside of the trunklid. I was told that there was no way my car (an 04 203 coupe) had the prewiring, that the head unit was incapable and so on. Guess what? It did have the stuff! So, the last word will be to check and see if the stuff is there.
Even if it isn't, it is possible to retrofit it anyway. It will be more complicated, and you will need more parts and have to take more of the car apart to install everything, but it still can be done. It just depends if it's worth it to you personally.
I hope this information helps.
