E-Class (W211) 2003-2009
Re-setting Service Indicator
Old Oct 1, 2005 | 08:33 AM
jimbo1mcm's Avatar
All Diesel Fleet !1983 240d stick,2005 E320 CDI Midnight blue, 2005 E320 CDI, Desert Silver, Kubota
If you change your own oil and do other maintenance items, the "Service_ Exceeded by....." comes on each time you turn the ignition on. If you look it up in your maintenance book, it tells you that you can get rid of it, only temporarily until the next engine start, by using the reset button. When you read further, it tells you to take it to a MB or other service center to reset.
Here's the procedure from the WIS from my 211.026:
1. Switch on ignition. Use the scroll page to get to the temp,mph page.
2. Press the scroll forward and backward button( down arrow) repeatedly until the service date is displayed.( or if it says," Service exceeded.."
3. Keep the trip odometer reset button pressed for approx 5 seconds until the Service Menu appears in the display.
4. Using the + and - buttons, select Confirmation of Service
5. Press the system selection button ( lower of page buttons at 6 O'clock position) to confirm.
6. Press again to confirm.
7. Service Confirmed appears in Multifunction Display
8. Press the same button to get to the standard display
9. Turn ignition off. The next time you turn it on, the reminder should not appear.
I guess Benz doesn't trust us enough to put it in the book.
Old Oct 2, 2005 | 04:58 AM
khaug's Avatar
'05 E320 CDI, '07 VW Touareg V10 TDI, 2007 Porsche GT3
2. Press the scroll forward and backward button( down arrow) repeatedly until the service date is displayed.( or if it says," Service exceedee...."
What screen do you need to be showing when you take step # 2?
Thanks for posting this.
Old Oct 2, 2005 | 05:43 AM
jimbo1mcm's Avatar
Service Data
Use the page scrolling button( 6'0 Clock) to get to the page which shows the outside air temp, or the MPH, the next item should be the service date( move with the arrow). When that appears, press the reset button for a full 5 seconds. The service data page should appear. Jimbo
