Fyi:current Recall And Tsb For W211
2005 E500 / 1993 MR2 Turbo
Came across this list of TSB and recalls for the 2005 W211. Check to see if any of these applies to you.
TSB:
1. TSB#885040 Structure: body: trunk lid (apr 2005)
trunk lid opens or closes too quickly while operating with remote button
2. TSB#424658 Service brakes, hydraulic (mar 2005)
activation of the sensotronic brake control with DAS software
3. TSB#276053 powertrain: automatic transmission
rough downshifting when accelerating
4. TSB#916085 seat belts
seat belt reminder telltale light illuminated and chime sounding when passenger's seat not occupied.
5. TSB#2005010011 fuel system, other
inspect high pressure fuel pump and replace fuel system components
" " " " " " " fule pump
6. TSB#2004070019 electrical system
flash central gateway
7. TSB#5410117 electrical system
consumer shutoff displayed in instrument cluster while driving
8. TSB#471030 fuel system, diesel:storage: tank assembly
procedure for when diesel fuel tank is filled with incorrect type fuel
9. TSB#424643 service brakes, hydraulic
squeaking noise when gently applying brakes.
10. TSB#010105 service brakes, hydraulic
voluntary recall campaign sensotronic brake control system
AS FOR THE RECALLS
1. recall no: 04V296000 service brakes, hydraulic
on certain vehicles, the electronic monitoring system of the sensotronic brake control is designed to monitor the pressure gradient within the high pressure line of the brake system. if an unacceptable pressure gradiant is detected, the system will switch, as it is designed to do, into the hydraulic function mode.
2. recall no: 05V133000 service brakes, hydraulic
on certain vehicles, the sensotronic brake control system may prematurely shift to the hydraulic back up function mode, die to deterioration of the wiring harness connection, or due to premature failure of the hydraulic pump.
TSB:
AS FOR THE RECALLS
Originally Posted by intrinsico
Is there a way to get a similar list for the 2003 W211?
Thanks,
Sergiu
Thanks,
Sergiu
http://www.edmunds.com/maintenance/MaintenanceServlet
