E-Class (W211) 2003-2009
E350 Engine Oil Level
Old Oct 21, 2005 | 02:10 PM
SteveBC16's Avatar
Veteran: Army
2019 E450 4Matic, 2018 E400 Coupe
According to the owner's manual, pages 320 and 321, the engine oil level can be checked using the Multi Function Display. After trying to find that screen in the display, without any success, I called 800-FOR-MERC for assistance and was advised that the engine oil level, with the new E350, can only be checked with the dipstick. According to the Customer Service Rep, that feature was discontinued with the E350.
Can anyone confirm that information?
Thanks,
Steve
Old Oct 22, 2005 | 12:50 AM
rockyfeller's Avatar
2006 E350 4Matic, 1990 300SE, 1984 190E, 1994 BMW 540ia
Thanx for reminding me....I knew the W211 had this capabilty but I'm now realizing that my E350 can't do this either. See how they are decontenting the car? Yeah we got a better engine, that's true. They save money and cut corners where they see fit. Thinking things like this are not necessary. Like a cheap console, no puddle lamps etc. BMW is also nickle and diming their customers. And we pay double price for each option we want, while it's cheaper or even standard with the competition. Thanks. Want to know why they get away with it even if you call to ask?....fine print always says: "features are subject to change without notice" What a line of BS. Still false advertising if you ask me. Meanwhile the rest of the auto industry continually upgrades their lines. MB used to be cutting edge but now more concerned about margins they are going to be passed aside the smarter those Japaneese guys get. (they are starting to get it right, look out) Sorry to complain, just an ol MB customer used to the way they used to make em.
Old Oct 22, 2005 | 01:21 AM
frogstaple's Avatar
2005 E320 CDI, 1999 ML430
Thanks,
Steve
Don't be too upset about it. I’m disappointed that my W211 didn't come with a dipstick.
Old Oct 22, 2005 | 09:38 AM
X72's Avatar
X72
Honda Accord
I would prefer a conventional dipstick too, frogstaple. But I think that you and I are in the minority. Most people would probably prefer the electronic check via the instrument cluster because then they then never would have to open the hood (bonnet). frogstaple, see the following thread which has a link to where to buy a dipstick
http://www.mbnz.org/forums/forums/th...osts=13&fid=18
William
2003 E320
Old Oct 22, 2005 | 12:52 PM
HELL ONA HARLEY's Avatar
Build date 2-04 E500
Call me crazy or perhaps old fashioned, but I would prefer a dipstick any time.... Nothing like seeing your oil level and being able to see what color it is.
Old Oct 22, 2005 | 01:50 PM
Dipstick should be there of course...I'm saying why not the best of 2 worlds?
Old Oct 22, 2005 | 07:17 PM
CE750's Avatar
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
Surely if enough of us feel like this, they may listed to us if we write or call them..
I did my share... many a call/letter about this "new" leaner and meaner MB. The sad thing is all of these idiots who compare directly the Japanese cars that cost less to MB are only harming this situation as MB can't seem to impress them with real value, they want the cheapest car and that's what MB is giving them, at the expense of making it a real MB.
Old Oct 22, 2005 | 10:33 PM
csumt76's Avatar
LS7 powered Corvette
I wouldn't put too much stock into the oil level readout in the cluster. I saw a few days ago a CDI that was overfilled by about a quart and half. The cluster indicated that the level was ok. I told the guy how much went in and he drained it, put in the right amount and it again said level ok after the waiting period.
Hands down the dipstick is where its at.
Old Oct 22, 2005 | 10:53 PM
CE750's Avatar
have you tried the "push odo reset button 3 times" method of reading the oil?
-ignition on pos 1
-display set to temp/speed readout
-press odo reset button 3 times
-select oil level / vin number page
-move ignition key to pos 2
-read quantity.
Mine is dead on.. I just did an oil change where they sucked it out of the top.. 7.0 L came out of 7.1 that was showing as quantity... We then added 2 gallons, or 7.5 Liters and the readout showed 7.5 after I checked it. Seems pretty accurate as long as you let the oil drain into the pan for a while before you do it. I always do it first thing in the morn...
Old Mar 18, 2019 | 04:10 PM
hopwoodmarkpaul's Avatar
2015 e350 bluetec coupe
Hi All I have a 2015 E350 bluetec coupe do you check oil level with dipstick and if so what grade of oil do you top up with? Cheers Mark
Old May 15, 2020 | 05:16 PM
CarsRcooL's Avatar
2003 E320
My 2003 E320 used to display the oil level but now it does not display oil level or gear indicator. All at once several things failed, SRS light constantly on, both seats will not move, steering column wont move and theres a 0600 serial communication malfunction. Oh the cooling fan runs at high speed constantly and the ac off light flashes.
