E-Class (W211) 2003-2009
Ex Japan E500 in New Zealand.
Old Nov 8, 2005 | 04:39 PM
Dan-the-Man's Avatar
07 E63
Hi all,
I have an ex Japan E500 W211. With the TV I can tune it to some of our stations and hear the sound perfect but I get black/white scrolling lines with no hint of a picture.
In Japan they use NTSC or SECAM (def not PAL)? and here we use PAL. I was wondering if this is the problem. Can the TV controller be changed?
If anyone here has had success with ex Japan models and getting things to work, like the TV, then I would be appreciative of any help.
cheers
Old Nov 8, 2005 | 05:07 PM
Flash Gordon's Avatar
2003 E500, 2004 G35X
In Japan, they use a slightly different NTSC compared to here. You will need an adaptor to get it to work. However, due to the TV is in your car which limits the space you can install the adaptor. I don't know it would be practical for you to install it. You can check with your local specialty store that sells the adaptor. It may be more practical for you to change the TV.
Old Nov 8, 2005 | 05:45 PM
Ken Uyeda's Avatar
Collections Ban
Lorinser
Actually he needs a Japanese NTSC to PAL converter... might be hard to find.
Old Nov 8, 2005 | 08:10 PM
schwarz's Avatar
124, 140, 211, 220, 221, 996
try to contact a member here called benzmodz who's located in sydney. he should be able to provide you the part you need.
Old Nov 8, 2005 | 10:11 PM
07 E63
Thanks Mate
