15 minute old new car problem
The first time i came to a complete stop was about 15 km from the dealership.
I then noticed that there was this (shunt) (lurch) feeling as if some one had nudged me from behind. Although there was no one there.
It happened again when i came to a complete stop.
This continued till i got home.
I took more notice of it and it seems that when the car is going into 1st gear (after a second or two) it lurches.
Now i didn't notice any thing like this when i drove a demonstrator.
I rang the salesman as the dealership was closed and he said NO THIS IS NOT NORMAL.
This is a brand new car 60 km with the 7 G transmission.
Any one know is this a computer problem or the gearbox itself.
It will be going back on Monday morning.
To say im dissapointed is an understatment.
PS: THIS ONLY HAPPENS IN THE (S) MODE AND NOT IN (C) MODE.
Honestly, mine acts similar but depends on temperature and how I have been driving the car recently.
Oh yea, and never ask a salesman about a technical problem.
Give the transmission some time to learn your driving patterns, shift points and what not. It will change to your needs.
but after 1000km everything went silky smooth
The exchange you are feeling is definitely the 2-1 downshift as you stated. That is why you do not notice it in "C" because you are always starting from second gear. As you drive the car and it adapts to your style, it will smooth out as well like everyone else said. Up until you took delivery of the car, it was most likely only driven in very short increments. On/off the boat, at the factory, at the vpc, on/off the truck to the dealer, and then during PDI inspection and detail.
The torque converter is not 100% percent efficient. The max speed the turbine will reach is approx. 90% of the impellar without a lockup clutch. A lot of 2 and 3 speed race cars use a lock up solenoid to put more HP to the ground on the top end. Ok, im done, that felt good.
If I use tiptronic to shift to 1st, and drive down the hill on a cold engine, the car still appears to downshift into a lower gear.. maybe there is something we're all missing here.. since this isn't some "defect" that can be corrected.
Watch the tach as you downshift, RPM's come up rather slowly. If it were the converter locking up, it would act like a manual transmission in which you select a gear just lower than your speed range, then sidestep the clutch. Likely the tires would "chirp" and the RPM's would catch up very quick if not instantaneously.
The lockup feature is simply a fuel economy/ heat reduction device. It "locks" at cruise speed to change from a fluid coupling to a mechanical coupling. The transmission input RPM is identical to engine RPM when in lock mode.
Older cars (in fact, a 1996-1999 E300D and E300 Turbodiesel) do not even have a lockup converter. Yet, they can still be downshifted to use engine compression for braking.
proceeded to clear the tranny memory thing. Didn't work. So they swapped
out the control box and I drove it a bit to see if it would do the 'relearn' trick.
Still lurched while coming to a stop at single digit speeds. So they put in a
new tranny (Starmarked covered). No lurching for the past 2 weeks now.
I also have a 99 E320. Up and down shifts are like butter. I find it hard to
detect the shift point if I'm not really trying to discern when they're shifting...
it's that smooth.
"It's normal" ....yeah, for a Merkin car, but not for a Benz, I opine.
My E55 did it for the first few hundred miles as did my E500 with 7G. If the symptom still exists, I don't feel it.
I hope they can fix up your car soon btw which dealer did u purchase your car from?
btw..
Another Harley / E-class owner!
"Hell on a Harley" and you should get on well!
Also, P-B-27.60/53 MAR05 – Rough downshifting when accelerating calls to install software # 000 448 38 10.
PB276053, is in the 5-4-3 shift range when accelerating around 40mph. Only a software change.
The new campaign for control unit flashing of the 06 E is dependent upon the VIN range and VMI data.
DAS software is updated monthly and will always have the latest control unit data/patch to flash with the newest version. A specific DTB could be revised at any time to include new information and software.
Too many variables, I can't post all the info. Bottom line, if you think you have a problem get it to the dealer and see what they can do. A good tech would be knowledgeable of all the latest DTB's related to the 722.9 and be familiar with EDAC procedure if replacement of the trans or a repair is needed.
I did a bit of running around yesterday with my wife and our 3 kids and at first i felt like the problem gone away.
Strange thing though as the car warmed up the problem came back although not as often as the day i picked it up. It didn't happen at every stop like the day before.
I also noticed it does not do it when coming to a stop up a hill. But is noticable when stoppping on flat or down hill.
It also only happens after the car has come to a complete stop.
Then after about a second you feel the gear going into first and the feeling of a bump (as my wife described it).
I do remember this thing happening to my 8 year old E320 but only when it when i came to a sudden or emergency stop.
It was as if the gearbox was trying to down shift to catch up the the rapid deceleration then it would shunt into first gear.
We are going out today so i'll see if there is any improvement. I am hoping as some of you have said that it is learning my driving style and will improve over time and go away.
W211_E350 I bought my E350 from G brothers in Mona Vale. Very nice people to deal with. My wife and i bought a ML500 from them in April 2003 and have been very happy with the way they have treated us.
True, most automatic transmissions only locked the torque converter at cruising speeds. But MB has decided to do it in lower gears too since sometimes these cars tow a lot of weight and 2nd and 3rd gear end up doing a lot of work to go up hills. You might notice, if you live where there are hills, that the transmission will not up shift when you ease up on the gas pedal. The transmission will only up shift (amazingly) at the top of the hill. I think that it does this because it has locked the torque converter to go up the hill.
I am curious to hear what the problem ends up being. I personally can sometimes feel a very slight vibration (barely noticeable) when the torque converter unlocks in 2nd gear at low speeds. If I have been coating in 2nd and then I might give it a bit a gas to accelerate and the car downshifts to 1st because of the slow speed. Other than this very slight shudder, my car has been completely smooth from day one!
I hope that this issue gets resolved,
Steve
I took the car back to the dealer's service department first thing this morning.
I had a technician sitting in the car with me and took the car for a drive. We did 3 stops from various speeds. The shunt happened on all 3 stops.
20 minutes in the work shop and i was told that there was no data in the computer to tell the gearbox when to shift from 2nd gear down to 1st.
They re set the computer and re installed all data as per factory specs.
We took the car for another drive. Did 3 stops and there wasn't any shunt.
I drove the car home and then to work and so far there hasn't been a problem. I will see this afternoon when i drive the car home but i am hopeful the problem has be rectified.
Now i can enjoy my new ride.
