E-Class (W211) 2003-2009
Nav problem setting "Home"
Old Nov 28, 2005 | 06:06 PM
aceman's Avatar
E500 4matic, 2014 GL320, 2013 C300, 2015 Stingray
Guys,
i'm having a hard time figuring out why my car wont hold the "home" setting. when i'm in my driveway, i hit NAV, Home, change, current position, then back...
any thoughts? Also - shouldn't my personal memory points show up on the map as icons? they don't appear.
Any help appreciated!
thx.
Aceman
Old Nov 28, 2005 | 07:23 PM
xraymd's Avatar
2008 335 vert, 2004 MDX
Did you try hitting "OK" instead of "back"? I think back does just that, backs you up a menu without changing anything.
Old Nov 28, 2005 | 09:05 PM
aceman's Avatar
found the problem...
I defined a memory point called home as well. That wasn't set at the correct location. I was changing the built in HOME soft button correctly but was choosing "Home" from my memory points which was set incorrectly. Don't ask me how i did that!
Anyway, must say, after 4 days with the NAV, i think its very good. This is my first NAV so i guess i don't need too many features. The usability IMO is very good once you play around with it.
Aceman
