2006 E350 4matic transmission issue... HELP
Any help is appreciated,
Alan
You have a 4-Matic, which means that you have a 5-speed transmission. There have been several cases where these transmissions have had internal fluid leaks that cause the valve body not to engage gears. Your issue has been seen in a few other posts here and that is what they have found. An internal leak.
You need to have this looked at ASAP, but the best thing to do is to have a video camera in your car and you need to videotape that dashboard and the gear shifter being in "D" and the rpm gage revving with no response. Otherwise, the dealer will always tell you that they cannot replicate the problem.
I would go as far as telling the dealer that you find this car to be unsafe and show them the video. They should be able to find many service bulletins that troubleshoot this issue.
I have been lucky and my car's power train has been perfect since day one and 13k miles.
I hope this helps and keep us posted on the outcome of this issue.
Steve
I drive a late 2002 registered (uk) E270cdi with auto tiptronic (one of the very first w211) with less than 30,000 miles, recently I started to have problems with the speed as the car slips as I try pull away, then jolts very badly as if the handbrakes were on and it does not want to move. sometimes when I take my foot off the acceleration and try to pull away again it jolts agains and then responds but when I try to move faster same problem again. I took it to the garage and after various test they said it a transmission problem. They said that the gear oil coolant (located within the radiator) had taken in water.AS a result the water has got into the gear box and oil has got into the torque converter. so they all have to be replaced. gear box,torque converter, radiator, reflushing of transmission after replacement.
big unbeliveable bill at the moment
I heard from unconfirmed sources that mercedes placing the problem prone gear oil coolant in the radiator is design flaw waiting to cause major problems as in this case where a faulty / licking gear oil coolant seems to have caused major problems by drawing water into gear box. How this could also have caused oil to be draw into the torque convertor, I don't know. please educate me
The dealer said it was a fluid leak and they had to replace some seals, gaskets, AT fluids etc....
So far so good. I'm wondering if they replaced it with an updated part or will I eventually have this problem again
Dealer first replaced the pilot bushing, but said they really couldn't duplicate the problem. Well the problem hasn't gone away, it's just that even I can't duplicate the problem each time I'm on the road. It happens intermittently.
