E-Class (W211) 2003-2009
2006 e350 stereo/nav ???
Old Jan 5, 2006 | 10:24 PM
Pacific NW Guy's Avatar
BENZO
I am a little confused on this one. I rec'd my car expecting a sweet HK stereo with 12 speakers. the i look into the grills on the back door and there are no tweeters. Mb is vague on the website when it comes to the stereo for the e350 but for the e55 it is very definite. did i ASSUME too much?
also for 2006 is the nav system all gray colors? the guide book shows bright coloring.
anyhow there car is sweet beyond that. had 6 miles when i got it and now has 200 so far so good.
Old Jan 6, 2006 | 01:18 AM
DWP's Avatar
DWP
'08 AM Vantage V8 - '03 E500
The HK audio system is optional equipment and, for '06, comes as part of the 526 or 626 "Premium Package." Both packages also include navigation, so if you have navigation, you should also have the HK system as part of the same package.
Sweet.
Old Jan 6, 2006 | 08:55 AM
BENZO
i understand that
but i do not see 12 speakers, i do have that package. i feel i ordered smething i did not get. i see the hk name on the front door speakers and the logic 7 in the stereo screens. my questions is regarding the actual placement of the speakers.
i know a bit about stereos and such and when i look at the rear door speaker grill i only see the larger speaker of the two. can someone who also has a 06 check to see if theirs is the same?
is the harmon the same in the 350 as the amg?? i am believing it is not.
Old Jan 6, 2006 | 09:12 AM
FlintCDI's Avatar
2005 E230 CDI
try this
Check out page 33 of the attached .PDF file. It might help
http://www.mercedestechstore.com/pdf...2008-05-02.pdf
regards,
Old Jan 6, 2006 | 04:16 PM
BENZO
I can not open that at work...
anyhow did they screw up the install at the factory???? Can anyone help? I will drive to the dealer today!
Old Jan 6, 2006 | 04:32 PM
Barry45RPM's Avatar
2015 ML 350
Go Listen to one with the basic radio. They are worlds apart! Then you'll know & it won't matter what you can see.
Old Jan 6, 2006 | 04:44 PM
BENZO
come on
if you saw empty holes would you not be pissed. so is there a hk marking on the rear doors??
Old Jan 6, 2006 | 04:45 PM
FlintCDI's Avatar
2005 E230 CDI
I could have been me, but my non HK 2005, and my HK 2006 dont sound that much different. Of course the '06 did come with one blown speaker
Old Jan 6, 2006 | 04:52 PM
Barry45RPM's Avatar
2015 ML 350
It wouldn't sound any better than the base radio, if there are components missing! If it sounds great, Its all there!
Old Jan 6, 2006 | 07:04 PM
CJ_E350's Avatar
2004 E55
Let me know what you find. I am about to take delivery on a car w/HK system from a dealer in Seattle.
Old Jan 6, 2006 | 09:55 PM
BENZO
all i am saying
is something is missing. i got my car direct from the factory since we have family in the company. i will look into tit all again but i am pretty sure it is off.....the sub is there, is that there on the base stereo?
Old Jan 7, 2006 | 04:12 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
just because you do not see something it doesn't mean that it is not there...the front tweeters are easy to spot - those are in the upper triangle at the mirrorbase...the rear tweeters are not vissible from the outside - those are hardly vissible from teh rearside of the doorpanel either (once the doorpanel is off)...those rear tweeter sit slightly higher then the main doorspeaker...
and no - the sub is not longer there with the base soundsystem (that has been removed from 05 and up or something like that).
greetingz,
Old Jan 21, 2006 | 03:18 AM
fadedinc's Avatar
no?
did this guy just say tit?????
Old Jan 21, 2006 | 09:37 AM
BENZO
maybe
i was typing that with one hand at the time.....
anyhow if you read my other post i was right, the speaker was missing....
