E-Class (W211) 2003-2009
slow electronics when cold
Old Jan 15, 2006 | 05:26 PM
hotwiredbenz's Avatar
'07 s550 4matic
anyone else notice that the digital stuff in the car (dash, stereo, etc) are slower when its cold? For example, when you switch through the different menus using the steering wheel controls, the transitions are really slow before the car completely warms up.
Old Jan 15, 2006 | 06:55 PM
DWP's Avatar
DWP
'08 AM Vantage V8 - '03 E500
Haven't noticed that, but your standard of "cold" (you don't say where you are) may be very different from mine. To me, "cold" is anything under 40 degrees F or 5 degrees C. Also, our car sleeps in an unheated but closed garage overnight, so it doesn't even get down to the outside temperature. What does you car say the temperature is when you notice the slow readings?
Old Jan 17, 2006 | 08:19 AM
Miguk_Saram's Avatar
'07 GL450
Yes.
I've also noticed a power [not surge, but.. flash?] at times - my instrument panel gets a little brighter a few minutes (<= 9) after startup.
Old Jan 17, 2006 | 08:43 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
This I believe is completely normal. Aircraft have the same problem. In the winter, on the first flight of the day in cold climates, its not unusual to see many of the electronics not only the displays to be not up and flight ready in some cases till we got to takeoff position. Some aircraft have aux heat in the electronics bay to minimize this.
