E-Class (W211) 2003-2009
Xenon Bulb replacement
Old Feb 15, 2006 | 08:32 AM
Bundy's Avatar
E500
I had to have on whole headlight replaced a few month ago and now the color of the new light and old light do not match.
How hard is it to replace just the bulb on a factory xenon headlight?
I have replaced some of the other lights (for color match) but have never messed with the xenon as I thought there were some special considerations for these.
Also, I know its in this forum somewhere but could someone quickly repost what the exact bulb I need to match the factory bulb is.
Thanks.
Old Feb 15, 2006 | 09:12 AM
W211 Ryda's Avatar
2004 E320
Thanks.
It's quite easy to replace the bulbs. Just twist off that big black circular plastic that protects the back of the housing. Then twist off the special HID connector (its actually the igniter). It should look like a square if I recall correctly. The bulbs you need are D2S. I would stick with Philips 4100K since this what usually comes as stock. This site is the cheapest I've found online. http://www.hidplanet.com/philips.html
You could also find some on ebay.
Oh yeah, make sure you clean the bulb itself with rubbing alcohol before installation. Any oil from your fingers could cause the bulb to explode due to overheating.
