Aftermarket Xenon Fuse Box
HELP!!!!!
Your problem sounds like a possible ignitor or ballast issue.
greetingz,
Also I keep thinking its not the ballast or ignitor because when you turn on the lights without the engine working they work fine. They only flicker upon startup while the engine is running. This is why I figured that maybe if I change the fuse from say 7.5 to 10amps it will fix the problem, however I can't find the damn fuse box for the headlights.
Any other ideas?
MB makes extensive use of its computer systems to control many many optional things, things that may be available in one part of the world, but not in another, as specified by that country's authorized importer/distributor, and how your car's features work based on the options you ordered when it was built.
To "zoom in' on your question, version coding tells the car exactly what options it has & how they should work in your given sales market. Thats why as you scroll thru "settings" there are NO menu choices for options that are not present on your particular car... the car "knows", or has been version coded, that those options are not present on your vehicle.
What MBENZNL is saying is that it sounds as if your car still has its OLD version coding so it "thinks" it has standard headlights, and it doesn't know you swapped them out, so the computer system is handling the electrical demands of the new lights with the electrical allocation of the standard lights, which the car still thinks are in the car.
Whew.....
