E-Class (W211) 2003-2009
Safety Recall
Old Apr 7, 2006 | 05:02 PM
pasto27774's Avatar
Safety Recall
I just received Saftey Recall #2005-110001 - new SBC bracket fixing possible ground wire problem.
Anyone else receive one? Thanks.
Old Apr 7, 2006 | 06:02 PM
konigstiger's Avatar
'71 Pinto
2005110001 JAN06 (original release DEC05) Installation of ground wires and bracket to SBC wiring harness - SBC may shift to the hydraulic back up mode due to the loosening of the ground wire harness connection over time.
Should be well known by now.
Old Apr 7, 2006 | 06:39 PM
pasto27774's Avatar
They must have broadend the VINs needing it. I just had my car in for service 2 weeks ago and they checked for any need campaigns....none needed.
Odd!
Old Apr 7, 2006 | 07:38 PM
TPAbnz's Avatar
2017 E300W
Try a search. There's quite a bit on this.
Old Apr 7, 2006 | 07:54 PM
pasto27774's Avatar
I've read most of them in the past. The question is, why am I getting the notice now? It's been out for a while and the dealer recently said the car was up-to-date.
Old Apr 7, 2006 | 08:14 PM
MBSvcAdv's Avatar
2006 MB
Arrow
Most dealerships should pull a VMI everytime you come into service, which would tell them what was and was not open on your car. I know you do not know me, but you can call me or e-mail me I'll check to see if your car is actually in the VIN range...
Steve Fordham
sfordham@parkplacetexas.com
(214)525-5498 direct
(800)336-7073 toll free
Old Apr 9, 2006 | 12:47 AM
HELL ONA HARLEY's Avatar
Build date 2-04 E500
Just received my notice today..... It effects 2003 thru 2005 E class, 2003 thru 2005 SL class and 2006 CLS class vehicles equipped with SBC.
Could this have been the cause for the few brake failures that have been reported here???? I'll probably wait till my next service (2500 miles) to have it done.
Old Apr 9, 2006 | 09:25 AM
platinumblue's Avatar
E320
Safety Recall
HELL ON A HARLEY
Safety Recall #2005-110001
April, 2006
Dear Mercedes-Benz Owner,
This notice is sent to you in accordance with the requirements of the National Traffic and Motor Vehicle Safety Act. WE SENT YOU THIS NOTICE BECAUSE WE ARE CONCERNED ABOUT YOUR SAFETY.
DaimlerChrysler AG (DCAG), the manufacturer of Mercedes-Benz vehicles, has decided that a defect which relates to motor vehicle safety exists in certain Model Year 2003 - 2005 E-Class, 2003 - 2005 SL-Class, and 2006 CLS-Class vehicles equipped with Sensotronic Brake Control (SBC). Mercedes-Benz USA, LLC (MBUSA) therefore has initiated a recall of these vehicles. Our records indicate that your vehicle is included in the affected population of vehicles.
The SBC brake system in certain E-Class, SL-Class and CLS vehicles, in certain instances, may shift to the hydraulic back up mode due to a loosening of the ground wire harness connection over time. In the hydraulic back up mode, the driver has braking power sufficient to stop the vehicle, although greater brake pedal pressure is required and the brake pedal travel will be noticeably longer which could lead to a vehicle crash.
Your authorized Mercedes-Benz dealer has available a bracket and replacement ground wire that it will install on your vehicle's SBC pump unit to correct the situation described above by preventing loosening of the new ground wire harness connection. This service will be provided free of charge. The working time required is approximately 1 hour. As a matter of normal service process, your authorized Mercedes-Benz dealer will also check for other repair measures which might be applicable to your vehicle and this may increase the required working time. Please contact your authorized Mercedes-Benz dealer for additional information and to schedule an appointment at your earliest convenience. Please mention Recall Campaign #2005-110001.
If you are no longer the vehicle owner, or have a change of address, please complete the reverse side of this letter and return the complete letter in the enclosed envelope. If this is a leased vehicle and the lessor and registered owner receive this notice, please forward this information by first class mail to the lessee. If you have paid to have this recall condition corrected prior to this notice you may be eligible to receive reimbursement. Please see the reverse side of this notice for details.
Please contact your authorized Mercedes-Benz dealer should you have any questions or encounter any difficulty regarding this recall. If your dealer is unable to remedy your situation please contact us at 1-J800) FOR-MERCedes (1-800-367-6372).
If an authorized Mercedes-Benz dealer or Mercedes-Benz USA, LLC, fails or is unable to perform this service without charge within 60 days, pursuant to law 49 U.S.C. Chapter 301, you may submit a complaint to the Administrator, National Highway Traffic Safety Administration, 400 Seventh Street, S.W., Washington, D.C. 20590 or call the toll-free Auto Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153); or go to http://www.safercar.gov.
Hope this is helpful.
Old Apr 9, 2006 | 10:11 AM
BudC's Avatar
2011 E550, 2013 GLK
If it's the same thing I'm thinking about, I had this done a long time ago. I pay attention to Konigtiger's Info and when he speaks, I head for the dealer
Old Apr 9, 2006 | 11:10 AM
pasto27774's Avatar
MB must have broadened the recall. I'm having mine done this Thurs.
Old Apr 9, 2006 | 12:15 PM
Perhaps its not and your letter is just around the corner.... If this is the recall you had done long ago, then I find it quite odd that I'm just now getting word since you and I both drive 04's....
Old Apr 9, 2006 | 01:00 PM
'71 Pinto
Once again, exact SAME recall dating back to DEC05 and updated JAN06 for work instructions. VMI has most likely completed the first round of VINs actually listed in the recall bulletin and is now notifying the remaining VINs. I’m assuming they did this as to not overwhelm dealer service centers and parts availability. Puzzling how MBUSA does things given the ramifications (i.e.: failures reported here on the forum) nevertheless it is what it is.
Old Apr 9, 2006 | 01:04 PM
Make sense to me.... Thanks Bro.
Guess if MB felt it was a serious matter then they would have had all the cars in at once and screw the dealers....
Old Apr 9, 2006 | 02:56 PM
CE750's Avatar
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
The only thing that pisses me off, is I showed BOTH dealers I bought the W211's from the bracket and read to them the operative words of the recall and asked them to apply the fix to my car and my mom's and both insisted that our VIN's were not included and not effected.. the Scottsdale dealer even brought out the shop foreman who made up some BS about the bracket being different now and my car not needing it... low and behold, magically now it seems to need it!
Going in for the 13K service in a couple of weeks where I'll get it done.. gotta figure out when I can get my mom's in! As my next visit to the bay area isn't till June and she's helpless at the dealer!
Old Apr 9, 2006 | 03:29 PM
drunkenoldman's Avatar
AMG SL 55
Just got it done on my 03 SL. It took the dealership 3 days to do it. Kind of a pain in the ***, but I like having brakes.
Old Apr 9, 2006 | 04:54 PM
Three Days????!
My letter says it will take an hour (1)......
Old Apr 9, 2006 | 05:12 PM
BudC's Avatar
2011 E550, 2013 GLK
Originally Posted by HELL ONA HARLEY
Three Days????!
It took my dealer three days too because (of course) they had to order the parts. Anyway, I'm sure the fix I got is the same one as in the Recall notice.
Old Apr 9, 2006 | 11:52 PM
NATS64's Avatar
2004 E500 AMG Sport and 2020 GLC300
I got mine yesterday.
Old Apr 10, 2006 | 12:21 PM
HotWheels500's Avatar
'05 E500 4-Matic Wagon
Yup, I just received one.
Old Apr 11, 2006 | 12:00 AM
RYNZ 00 CLK's Avatar
SRT-8
re
Got mine today ..going in the morning
