Shifting down with an automatic transmission
04 E320 4 Matic, 95 Audi S6, 99 Carrera 4 Cabrio, 12 Fiat 500 Sport, 00 BMW R1200C 10, BMW R1200R
Originally Posted by revstriker
1)Ok, next time it snows try this: turn ESP off and from a stop, try and take a corner. You will see that you fishtail. Now turn ESP on, and try the same thing. You will see that as soon as the car starts to slide, ESP takes over and stops it.
2)An AWD car DOES NOT provide power to all 4 wheels at the same time, so a downshift in such a car would not effect all 4 tires.
3)There is no method out there that will completely guarantee you a no-slide situation every time. Of course aggressive downshifting is bad. So is aggressive braking, even on a car equipped with ASB. And yes, ESP WILL help you in a situation where you are sliding straight. It will still sense the wheel that is sliding along with the wheels that are not and apply braking.
4)You are mistaking AWD with 4WD. Most AWD vehicles only provide power to one or two wheels at a time. They just have the ability to supply power to all 4 wheels, just not at the same time.
5)Well, to me, "locking up" implies that they are no longer turning. When your engine slows down the forward momentum of your drive wheels, they are still turning. If this is done properly, it can slow you down while maintaining control of the car. Similarly, when you brake, if you brake hard, you can and will slide. When you better control your braking, you better control the car.
There are two ways of getting out of a slide when your car is fishtailing. One is to steer in the direction of the skid which catches the front up to the rear. In driving school, they also tell you to lift your foot completely off of the brake. This allows power back to the rear wheels giving them an opportunity to "bite" and help straighten you out. The other way is the ability to individually brake certain tires. When the rear swings out to the right on a skid, braking can be applied to the right front tire which will encourage the front end of the car to catch up to the rear. Much like steering into the skid. This is what ESP does. By the way, ESP is traction control.
Steve, although I do disagree with some of your points, I too understand what you are saying. I think the whole thing began really with a misinterpretation of downshifting. This term can be used for different things. Downshifting to pass for instance is completely different than downshifting to slow down. However, slowing the car down by controlled downshifting in addition to braking is an effective way to maintain control of a car. With ABS, and traction control technology today, there may be easier ways of controlling the car. But if anyone's ever spent some time in the snow in an older car without anti-lock brakes, or traction control, etc., they most likely learned control via downshifting.
2) Where did you get this information about the Mercedes AWD? It is quite wrong. Mercedes Benz 4-Matics do send only 40% of the torque to the front wheels and 60% to the rear, but this is hardly much of a difference. AWD does provide power to the 4 wheels at the same time. This is a FACT in both my Mercedes and my Audi.. The difference is that the 4-ETS that is part of the 4-matic system has open differentials and uses the brakes to stop the wheel that is spinning out. When the wheel that is spinning out is stopped/slowed down, the power then gets transferred to the rest of the wheels through the open differentials. This system on the 4-matic uses some of the sensors that the ESP uses, but it is not the same thing. Like I said, the ESP stops yawl. The Traction control or 4-ETS on a 4-matic stops excessive wheel spin. My old 1986 4000 Quattro was AWD all the time with a true 25% to each wheel distribution. However, it was still possible to spin out if one wheel lost grip, with the differentials locked (all 3) then the car was a 4X4 and did not allow only one wheel to spin, this is what made turning hard. The 4-matic system knows your speed and steering angle and knows how much speed differential should be between each wheel. This gives you the lack of slip of a 4X4 yet lets you turn on a dime because the differentials are still open.
3) Of course this is true and I think that we have been in agreement here all along. The only reason that the ESP still works (better than any other system) on ice is that it still can apply the brake on just one wheel. This can give you just enough drag to kick the car around the way you want it to go. But this is why if you have all wheels on a skid due to a downshift on a 4-matic, the esp is already fighting a worse scenario.
4) Please refer to #2 above. Mercedes 4-Matics along with Subaru, BMW, and Audi send power to all 4 wheels at the same time all the time. The difference is that smart AWD can also direct power to just one wheel. A 4-Matic system can even send power from right to left as well as front to back. Not to mention that one wheel can get up to 70% of the torque for traction. 4x4 simply locks everything up and only lets 25% of the torque to go to each wheel.
5) I think that I used the wrong term with locking up. But you know as well as I do that if you need to stop in a straight line, brakes usually have pretty much the exact same stopping power in the rear axel this means that even if they do lock, they should lock at about the same time and make you skid in a straight line. Like I said before, when you downshift, and you are not touching the brakes, the rear wheels can brake unevenly and guarantee skid and a fishtail where as if you just locked the rear wheels at the same time it would take longer to fishtail after you start to skid. This is why the ABS would work at making sure that the wheels on each side do the same amount of work (skidding or not). This is why I want to say once again that even if you downshifted rather severely (in stupidity) and the wheels started to skid unevenly: a 4_matic could break loose all 4 wheels and really get you going out of control. The ESP starts working only after your car wobbled and since you are NOT accelerating the 4-ETS is not there to help. The only thing left to do is what you mentioned that they teach a driving school which is over and under steer correction.
I think that you might not be too familiar with 4-Matics. They are a truly wonderful system in adverse winter conditions. I don’t know if you ever saw the video I posted over a year ago of me making doughnuts in my E class. I had it under steering and over steering while maintaining control at all times. Snow was flying everywhere and the car had all electronic driving aides turned off. If I had them on, the throttle would have been cut and the ESP brings the car to a halt (in other words, NO FUN).
Another reason why AWD has become miles better than 4x4 for snow/ice driving is that the ABS had to be deactivated when driving with locked differentials. My Audi S6 can send power from the center differential in forms other than it’s standard 50/50% with the ABS on, but the second I lock the rear differential the ABS OFF light turns on on the dash. This is not the best thing to deactivate sometimes (unless you want to play around).
I know that we have gone on a tangent and we are now splitting hairs, but it is nice to type a bit sometimes. The best advice that I can ever give someone when they start driving in snow (aside from good snow tires) is to only do one input at once. When coming to a turn, do all your stopping (if no one is behind you) before you initiate the turn, maintain the speed while turning and then only start accelerating once you are done with turning. You don’t always have to do this, but it sure helps at the start. Also, take you car out and test it when the first snow storm comes.
Take care,
Steve
Take care,
Steve
Take care,
Steve
Steve, it's been an interesting discussion, and I do agree with your advice quoted above. As for AWD, my knowledge of this might be older than yours, and I admit, not specific to the vehicles you mentioned. However, in AWD vehicles of the past, there was still only two wheels receiving power at any one time. The power was split between the front and the rear, but only one of each would receive power. That power would then be given to the left or the right wheel, but not split between them. If all 4 wheels received power, you would have some issues when turning corners as one wheel would need to turn at a faster rate than another. Anyway, as I said, my knowledge of this is not specific to any one type of car, and it would not surprise me to find that technology has advanced to the point of controlling this better.
The system of AWD that you described was quite prevalent in domestic cars and were very hard to handle sometimes because you never knew when the power was going to be transferred from one axel to the other. This let you start skidding and then you would feel a jolt of power to the front/rear wheels and you sometimes still ended up stuck.
Audi Quattros have been wonderful since the late 1970's and the 4-Matic system of 1998 and newer cars is exceptional. Even on an E500 4-Matic, you will have a hard time breaking wheels loose if you accelerate hard and turn at the same time. The grip and power distribution is wonderful.
Talk to you in other threads!
Steve
1 Post
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
I must say that is is nice to be able to have a discussion without personal insults or stupidity.
Originally Posted by CE750
On of the best by-products of debating with Rev.. and I'm not sure if it's cause he's mod either... as other "mods" hold nothing back when they disagree with members.. he's just a nice guy, even if he's wrong about most everything
Steve
And by the way, I'm actually "right" about most everything....
#32
Well, he is from Texas and his signature has tanks on it. I thought I should be very nice and careful, just in case.
Steve
Steve
And yes, the Tanks are something else I used to drive a lot, but I'm not alone. CE750 is an old "tanker" as well.
#33
"I personally only downshift in city driving when I might have passed someone aggressively and then I don't want them to see that I had to immediately put on the brakes ahead of them."
This made me chuckle. I'm so happy to learn that I'm not the only one who has done this. ;-)
#34
1 Post
'08 AM Vantage V8 - '03 E500
Slowing with the transmission is also a useful technique when you're over the speed limit and you spot the motor cop takin' pictures from behind the shrubbery. It may be too late to avoid being painted by the radar/laser, but if you slow down with the transmission instead of the brakes, you at least avoid the admission of guilt from flashing your brake lights.
