E-Class (W211) 2003-2009
Keeping the CD Player paused...
Old Apr 21, 2006 | 06:48 PM
PSG's Avatar
PSG
E500 4MATIC
The following is what is normally the case and what I therefore call "normal" operation:
Prior to turning off the car I press Mute to pause the CD Player (or Changer). When I next trun on the engine, the player is still paused (muted).
The following then is not normal: Periodically, and without any obvious action on my part, the player will un-pause after restarting the car.
As randomly as it comes, the system seems to revert to "normal" after a period of time, although right now I am in the abnormal state.
I have tried muting before the engine is turned off and also after it is off but before pressing the Start Engine button (Keyless Go). No difference. I saw a somewhat similar post a few months ago regarding retaining the volume so I assume this is not completely unique but insights and suggestions are welcome as I now have to remember to mute the player (or radio) as soon as I start the car.
PSG
Old Apr 21, 2006 | 10:46 PM
Barry45RPM's Avatar
2015 ML 350
Why do you mute the audio prior to shutting down the engine & leaving the car?
Old Apr 21, 2006 | 11:14 PM
PSG's Avatar
PSG
E500 4MATIC
I mute it because I don't want it to be on when I start the car. I may mute it minutes before I stop driving....and likewise, I may not want any audio until I've driven a little while.
Old Apr 21, 2006 | 11:22 PM
Benz-O-Rama's Avatar
You say:
"...although right now I am in the abnormal state."
Does this mean you're drunk?
Old Apr 22, 2006 | 01:24 AM
WEBSRFR's Avatar
Tesla Model S P100D
Maybe I'm missing something here but why not just turn off the CD player? You can then turn it on later when you start driving. That's what I do...
Old Apr 22, 2006 | 10:07 AM
PSG's Avatar
PSG
E500 4MATIC
I could turn off the entire NAV system, but I shouldn't have to. I want the system to either operate the way it seems to be designed or, alternatively, the same way all the time.
My general question then is - does your system work as I have described as "normal".
When you say "turn off he CD player" do you mean switching to Radio, etc.
Old Apr 23, 2006 | 12:02 AM
alewifebp's Avatar
2014 BMW 550i
I think he meant to turn the entire system off, which is what I do. But, it's an annoyance that the nav also shuts off too. We've talked about this a long time ago here on the forum.
