how hard to put bixenon lights ???
one fast skateboard :)
I have regular projectors with aftERMARKET hid my question is how hard is it to swap the projector to a bixenon shroud is this possible and what kind of wiring i will have to deal with ??? thanks ahead
Originally Posted by 3tjohn
I have regular projectors with aftERMARKET hid my question is how hard is it to swap the projector to a bixenon shroud is this possible and what kind of wiring i will have to deal with ??? thanks ahead ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
- what is the name of the aftermarket HID? rebased bulb?
- one can look into replacing the existing projector with a bix projector, which
will be made much easier if the bix is same size lens as well as near identical
dimensions as the one you're pulling out.
- wiring of the bix shutter should be wired in to the high beam circuit. if you
have H7 in the adjacent headlight compartment, then you can simply wire in
the bix shutter/solenoid into the high beam wiring
well my headlight is projector with aftermarket h7 hid bulb and i am actually just using is the bixenon schroud which is the housing no projector included with the bixenon i am getting . how hard is the wiring is it just a plug and play ? thanks again
