E-Class (W211) 2003-2009
Locator Lighting Erratic
Old May 19, 2006 | 08:27 AM
KShortill's Avatar
2004 E 4matic StationWagon
Hello all!
I wonder if anyone has any thoughts on diagnosing what might be the problem here:
On an E500 wagon, the daytime running lights and locator (sometimes call "convenience") lighting are enabled, and the light switch is in the "auto" position.
When the car is first unlocked after it has been sitting for awhile (e.g., first thing in the morning), the interior lighting works as described in the manual, but no outside lights, other than the puddle lights, turn on. My understanding is that the fog, parking and license plate lights also should come on until either a door is opened or 40 seconds goes by. (The wagon is parked in a dark garage.)
I do not believe this to be an issue with ambient lighting in my garage, because if I immediately relock the car and unlock it, the puddle, fog, parking and license plate lights do come on, as I believe should have the first time the car was unlocked.
Thoughts?
Many thanks, in advance,
K.S.
Old May 19, 2006 | 08:39 AM
paulv's Avatar
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
I had almost a similar issue and tried to no avail to set up the lighting via the MFD. I had the dealer go in with StarDiags and set it up. IT's OK now with the parking, fog, interior and puddle lights coming on when locking/unlocking.
Regards,
Paul...
Old May 19, 2006 | 12:38 PM
ATS's Avatar
ATS
2004 E500 / 2001 C240
Press unlock twice to get it to work.
Old May 19, 2006 | 05:05 PM
konigstiger's Avatar
'71 Pinto
Originally Posted by KShortill
When the car is first unlocked after it has been sitting for awhile (e.g., first thing in the morning), the interior lighting works as described in the manual, but no outside lights, other than the puddle lights, turn on. Thoughts?
I agree with Paul.
Your dealer needs to check the rain light sensor (RLS) software version. If software version is 8.0 or lower the light threshold needs to be adjusted. The set value needs to be decreased. The exact amount has to be determined on the vehicle. A starting point of 74 is recommended.
Old May 22, 2006 | 11:19 AM
KShortill's Avatar
Double Click
ATS,
Is the double click documented in the manual anywhere? I will check your suggested approach tomorrow.
Many thanks,
Kevin
Old May 23, 2006 | 10:18 AM
ATS's Avatar
ATS
ATS,
Many thanks,
Kevin
No, although when I walk up to the car and it is dark, one click will open the doors, two clicks will turn on the fogs and the puddle lights.
Old May 23, 2006 | 03:23 PM
paulv's Avatar
The way mine is set up, one click will open doors and turn on fogs/puddles when dark (and also turn on the interior dome light). I'll have to try and see what happens with 2 clicks.
Regards,
paul...
