Warranty Expiring Soon
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
My car warranty is expiring soon as my E is getting close to 50k miles. I did purchase an extended warranty from my dealer, but I don't believe the extended warranty covers scheduled service calls as covered on original warranty (?). I was wondering if it would be a good idea to schedule getting some items done now before original warranty expires. For example, the COMAND Nav update to allow playing MP3 in single DVD slot, etc.. Thanks for any advice!
2003 E-500
I would check Konigster's excellent Sticky Post on Service Campaigns at the top of this board and note all that apply to your VIN. Hopefully, you will have a good realtionship with one of the Service Managers at your dealer by now. Talk to that individual and point out any TSB's you think should be done on your car and then ask for their advice on what else might be likely to fail. IF you have a good relationship. they will tell you about things that they should probably do and ask you questions, such as "Does it have any jerky shift points?" I had this occur with a previous E-320 at about 45K miles, and got a transmission overhaul, a new fuel gauge and a couple other things that "might go bad in the future" done. That car ran well until I traded it in three years later. I also wrote a nice letter to General Manager of the dealer complimenting my Service Advisor and have bought two other new cars from them.
check to see if your rear a/c vents are always hot, or maybe just complain anyways, theres a heater valve that goes bad on 211 that causes that, if you had to do it customer pay it will be like 3 or 3.5 hours of labor + parts
check to see if your shifter seems a little loose or have any play in it shifter bushngs usually dont go bad until like 8-100k tho so your ok on that
see if you can get a warranty brake fluid and coolant service
make sure your sun visor flaps that cover the mirros are not loose if they are complain
GET YOUR BATTERY CHECKED BEFORE IT GOES OUT OF WARRANTY!!!!! they are expensive
make sure your keyless entry works from upclose (infrared) and far away (radio frequency), both keys
cant think of anything else, hope that helps
Received 4,435 Likes
'71 Pinto
Originally Posted by Thrillhouse
all service campaigns are warrantied for the life of the vehicle, so no worries on those - make sure your sun visor flaps that cover the mirros are not loose if they are complain
Actually they're covered: P-B-68.60/37d FEB06 Sun Visor Mirror Cover Broken, Models 210, 211, 215 (as of 2003), 220 (as of 2003), and 230. Replaces the vanity mirror cassette.
'71 Pinto
Is that a campaign recall or dtb, dtbs are NOT covered for the life of the vehicle only service recall campaings
It is my opinion that an argument could be made to the MBUSA SPOM in this particular instance whereas MBUSA acknowledged a problem and married a remedy to it covering vehicles back to 1999 yet the actual document is dated FEB06 (initial release JAN05).
DTbs are not covered under warranty, its not the dealership its benz, they will basically say, things break we are just telling you how to fix it. Basically the recalls are safety related items so they will always be covered, thats why I told him to complain about certain things
'71 Pinto
DTbs are not covered under warranty, its not the dealership its benz, they will basically say, things break we are just telling you how to fix it. Basically the recalls are safety related items so they will always be covered, thats why I told him to complain about certain things ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
