SBC Recall Question
The dealership advised today (Tuesday) that the part is on national backorder and won't be available for 2 - 4 weeks. My service advisor now says the car WILL be safe to drive until the regulator can be replaced, and has requested that I return the loaner and retrieve my car!
Can anyone (Konigstiger) shed any light on what's prompted the replacement of the SBC regulator, and what risk I'm running driving the car in the interim?
Thanks.
Can anyone (Konigstiger) shed any light on what's prompted the replacement of the SBC regulator, and what risk I'm running driving the car in the interim? Thanks.
The underlining reason for this recall is that the SBC may shift to the hydraulic back up mode. In the hydraulic back up Mode the driver has braking power sufficient to stop the vehicle however, greater brake pedal pressure is required and the brake pedal travel will be noticeably longer which could lead to a vehicle crash.
Although you mention your car has never shown signs of brake problems, what if it does while you’re waiting for the part to be delivered? The dealer should allow for the loaner until all repairs are completed. If not simply mention “safety” recall!
If you should decide to retrieve your vehicle make certain the dealer supplies a dated invoice stating the vehicle is safe to drive and the required part, as per safety recall 2005110001, is on national backorder.
Note: If they fail to perform this service within sixty days you can submit a complaint to the National Highway Safety Administration 1-888-327-4236.
I still have the loaner. When I picked up our CDI tonight, the "check engine" light was illuminated, so the car remains at the dealer.
Thanks Konigstiger and all who responded. Mark, I hope you have better luck with your recall! I'll let you know if this story has any further interesting chapters.
