E-Class (W211) 2003-2009
Put on CLK grill
Old Jul 29, 2006 | 05:14 PM
CombatBenz's Avatar
Put on CLK grill
But now when I pop my hood the plastic peice that pops out, doesnt pop out, it hits my grill and gets stuck behind it...
I guess im a bit confused because it was a perfect fitment.
any ideas? or do I just live with it?
thanks in advance..
PS- I got it for free.. I wouldnt pay for it. My buddy had it on his E55.. and sold the car, and had it layin around in his garage.
Old Jul 29, 2006 | 07:30 PM
xabo's Avatar
'20 S63
You'll have to trim one side of your hood latch.
Old Jul 29, 2006 | 07:58 PM
CombatBenz's Avatar
can u give better directions.. trip how? with a file? file it down?
Old Jul 29, 2006 | 08:13 PM
jangy's Avatar
2015 S212
Just take it back off and be done.
Old Jul 30, 2006 | 03:23 AM
tbone's Avatar
E500 Sport
The fact that it doesn't fit is a sign from above telling you that the stock grill looks better. Told you not to do it!
Old Jul 30, 2006 | 03:51 PM
xabo's Avatar
'20 S63
You can either file it, or cut it off. Your latch should have a flare on each side where it comes out of the grille. You'll have to modify one side so that it'll come through the hole.
Old Jul 31, 2006 | 08:51 AM
Miguk_Saram's Avatar
'07 GL450
If your buddy had it on his e55, there shouldn't be any adjustments necessary. It should be the same fit. Then again, ask you buddy how it was installed on his e55.
Just to clarify though, this is a "CLS" grille, as opposed to a "CL" style grille, right? The "CL" style fits without modification. If, however, you've actually taken the grille off of a CLS... then I dunno..
Edit: After reading more carefully, the original post says "CL(K)", not "CL(S)"; I stand my ground though.
