E-Class (W211) 2003-2009
2006 E55 bumper question
Old Aug 29, 2006 | 12:58 PM
Mr.Gearhead's Avatar
2008 Aspen, 1970 Corvette, 2000 Corvette and 2009 Legacy Limited
Talking 2006 E55 bumper question
Hi all,
Will a 2006 E55 bumper fit on my 2006 E350? It look like it would without issues but there are two triangles on the front between the headlights that I don't have on my stock bumper. Also, will my stock trim fit the E55 bumper. I know I need to get the mess screen for the bottom and the fog lights as well... not sure where to get the fog lights with screens. I am looking to make my E350 into the sport verison....
I have someone at a body shop that can help with the painting part... just not sure about the fitment and molding pieces...
THANKS,
Anthony
Old Aug 29, 2006 | 01:09 PM
cyclerider's Avatar
Harley-Davidson
Originally Posted by Mr.Gearhead
. . . there are two triangles on the front between the headlights . . .
That is for the headlamp washers which your car does not have.
Old Aug 29, 2006 | 01:18 PM
So what can I do about that? are they just covers that slip in there?
Old Aug 29, 2006 | 02:28 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
I Installed The AMG E55 Bumpers/Skirts and Quad Exhaust on my 2006 W211
They fit perfect!..Also Added the Large Brakes and AMG 19s to complete the look As long as You use ALL OE MB Pars everything will fit!
Old Aug 29, 2006 | 03:06 PM
cyclerider's Avatar
Harley-Davidson
The triangle-shaped headlamp washers pop out from the bumper when you activate them. They are part of the factory installed Xenon Lighting Package. Ask your body shop friend if they can fill the holes before they paint the bumper to match your car.
Old Aug 29, 2006 | 03:58 PM
Did you get the side skirt as well?
Can I get the washer cover somewhere... maybe "molded" in? That is are really big hole to glass...
Old Aug 29, 2006 | 04:13 PM
cyclerider's Avatar
Harley-Davidson
Can I get the washer cover somewhere. . .
Body shops can order replacement parts. I don't know how they would secure the cover in the hole, since the part the cover attaches to (washer mechanism) doesn't exist on your car.
edit: See post #12 below
Old Aug 29, 2006 | 05:21 PM
Mostly like just get the holes filled in then. Bigger question... Is the E55 molding different than E350 front bumper? Will mine transfer?
Old Aug 29, 2006 | 09:05 PM
Yes I installed the COMPLETE set front / rear bumpers and side skirts...
Re the Bumper with headlight washers ..I Would leave it alone..as You might want to add the H/L washers later?
The Bumper Impact Inserts are the SAME so Yes they can be reused..But the AMG E55 bumper uses different fogs/grills
Old Aug 29, 2006 | 09:07 PM
This is NOT Correct..The Front Bumpers with Headlight washers use a Cover that is Hinged to the BUMPER NOT to the Headlight washer...as the Headlight Washer Pops Up when in use
Old Aug 29, 2006 | 09:13 PM
3tjohn's Avatar
one fast skateboard :)
I purchase mine from local dealer and they are also painted .
You will also need a e55 bumper bracket ( platic thingy's that attach to the inside of the bumper) unless your stock e55 bumper came with it .
Old Aug 29, 2006 | 09:24 PM
cyclerider's Avatar
Harley-Davidson
Thanks for the correction. So the covers will not be a problem even though there are no washers beneath them. Anthony, I hope you see this post.
Old Aug 29, 2006 | 10:20 PM
chenry's Avatar
05 E500 Wagon
you can also get the E55 bumper without the washers...
Old Aug 29, 2006 | 11:07 PM
No Problem Using a Front AMG E55 Bumper WITH Headlight washers...Even IF NO Washers are Used..as The Front Bumper on Our 2006 W211 has the Headlight washer Bumper..But The Car does NOT have the headlight washers ...yet.....as The Headlight washer cover IS Hinged to the Bumper NOT the washer assy
Old Aug 30, 2006 | 12:30 AM
SWEEEEEEEEEEEEET!
I can use my original bumper molding
I can just get the wiper covers in Pewter
I guess I need a bumper bracket for E55??
I guess my car is going to look wicked... to me anyway.
Hey MARK... how about some pics of the conversion?
Anyone have info on side skirts? Rear bumper? Need anything special here?
THX
Anthony
Old Aug 30, 2006 | 09:36 AM
chenry's Avatar
05 E500 Wagon
both are simple bolt on...your only challenge will be the exhaust / it's nearly impossible to adapt the stock mufflers to work with tips that will look right with either the amg/sport (provision for dual singles) or the amg/e55 (provision for dual dual tipped exhaust)...your best bet will be to find aftermarket or oem replacement mufflers with the correct fit (and tips) / it will be easier to find dual duals (e55 style) vs dual singles...this because the latter is much more rare vs. the former
Old Aug 30, 2006 | 10:00 AM
SWEEEEEEEEEEEEET!
THX
Anthony
Re the bumper bracket you Will need the AMG Bumper Inner reinforcement and foam..its best to locate a complete AMG E55 Bumper ..Try Steve @ MBENZNL.com He has One set left !
As For Pics..I Dont have any and No one at the GTG took any..I WILL Take some this weekend...Looks Like a E55 with AMG19s the LARGE Brakes
and the correct AMG Quad exhaust
Old Aug 30, 2006 | 10:15 AM
Bumper foam? Can it be purchase seperately? I can get my hands on a E55 front bumper relatively cheap... under $200. Just trying to understand what is will take to do this... It seems easy enough... THANKS for all the help so far!!!!
Old Aug 30, 2006 | 11:52 AM
The Bumper foam is in several pieces and goes behind the bumper reinforcement
on both front and rear bumpers..and It IS different from a Non AMG bumper
You can buy them from the dealer
