should rear drop equal front?
The free links I sent did not have the longer screws, so DO NOT add washers to it.
Thanks again Jang. I'll keep an eye out for em. Hey do you know how much the links are from the dealer? I think I'm gonna buy a stock set for the winter. I'll put my stock wheels back on and put it back to stock height. They're predicting a crazy winter around here.
There is also a sliding ruler style link for the rear that you can adjust the length on if you really want to go that route.
Here's the before pics.
2 fingers in the front, 3 in the back.
As you can see, I had to bend the bracket to get the new longer screw in there.
You can now see the results although notice the rear is still a bit too high for my taste
Using tips from another post I put washers in there too just because I didn't want to blow 70 bucks on a dremel and I'm not very good with my hands. I know i would've really messed something up. Put 3 in each side.
My car turned out really uneven with the passenger side lower so I added more links to the front driver side until the front evened out. This is probably because I bent one of the link really bad and it was never the same even after I bent it back.
THe passenger rear is a bit more lower but like half a finger but let me say one can totally tell the difference.
So, I got 7 (yes 7) washers on the driver's side and 5 on the passenger side with plenty of thread left over.
Oh well, I guess I can say I've done what I set out to do. HOpe this helps someone out.
Thank God you did that. Your car was WAAAAAAY jacked up in the air. How could you stand it?? Anyway, looks much, MUCH better. It looks like you could still drop it a bit in the rear. You didn't do anything to the rear sensor, right? Do what Jangy said, and bend that bracket in the rear. Just a little bit at a time though.
Looks good!
Looks good!
IMHO, the rear really does need to go down a little more but I don't know what you guys mean by bending the rear sensor bracket. That thing is welded to the car. Do I just yank on it until it bends? Thanks for the comment.
Last thing, be careful with the front. Make sure the bracket does not break at the bend points. that is exactly why I use a press to do it. Mine was the same drop as yours in the front and I used no washers.
Lookin much better. Drive safe, bro!!
Also, I noticed a different part number than the E55 link I mailed Benz-o. Maybe he can do a comparison of his to the ones I sent to see if they match up and how much of a difference the bending makes?? They look identical.
As for the rear, I started out only doing one of the bolts, the one that is "lower" and it dropped about a finger. It was only when I did both that it went down 2 fingers,
Crazy, if I have some time today, I'll bend the bracket and let you all know what happened.
