Anyone know how to remove Keyless-Go shifter?
I'm considering a swap out of my OEM keyless go shifter with an aftermarket keyless go shifter. I have no real good reson for doing this other than the mod bug had taken control over my entire life. Anyway, I looked at the shifter and there's no ring at the bottom to unscrew or any little allen bolt to loosen or anything like that. Has anyone done this? If so, can you supply me with the how-to?
Thanks.
Thanks.
209/W210 Estate /W211 modded by MBENZNL
Remove the shift knob boot..(Lift it up) Then You will see how the shift knob is secured..it has a twist lock at the bottom..Unlock it and remove the shift knob with the leather shift boot
w211 AMG
Is there such thing as an after-market shifter for the key-less go? I have never heard of such thing. Can you post pics. A carbonfiber ****ft knob for the keyless go would be really cool.
